Check engine light on with codes
I checked the codes and got these
10 PCM - P1416 H C - AIR System bank 2-B
60 IPC - B0516 H - Speedometer Signal Circuit Malfunction
60 IPC - U1160 H - Loss of Communications with LDCM
A0 LDCM B2282 H - Battery #1 Fault DCM-LEFT
A0 LDCM B2284 H - Battery #2 Fault DCM-LEFT
A1 RDCM B2283 H - Battery #1 Fault DCM-RIGHT
A1 RDCM B2285 H - Battery #2 Fault DCM-RIGHT
A6 SCM No Comm
B0 RFA C2100 H C - Left Front TPM Sensor Malfunction -TPM
B0 RFA C2105 H - Right Front TPM Sensor Malfunction -TPM
B0 RFA C2110 H C - Right Rear TPM Sensor Malfunction -TPM
B0 RFA C2115 H C - Left Rear TPM Sensor Malfunction -TPM
B0 RFA U1255 H - Serial Data Line Malfunction -RFA
what the heck is going on with my car
check you AIR tube that runs behind the intake to each side of your headers/manifold. they bolt together by the exhaust manifolds/headers and your gasket may be shot or the bolts have come loose.
off to check the air tube
thanks
Remove the rubber hose that goes to that check valve, spray a good shot of Carb cleaner in there and blast it through with some compressed air and then spray in a good shot of WD-40, hook everything back up and see if that helps.
Beats disassembling all that stuff!
Let me know how you make out.
BC
BC
If you have a air compressor you can take the hose off the right exhaust manifold and also where it Tees off from the left side of head and with air test to see if air goes from left to right but not right to left.
This also would pinpoint if the hose is leaking and check the gasket where AIR bolts to exhaust.
Problem is it might not be the checkvalve but instead is the front and rear O2s for that side are not working correctly and the short term fuel trim for that side then does not go to a sudden lean condition when AIR pump goes on.
Before ripping the valve out if you have a PCM scanner on a cold start watch what the right O2s and STFT report to know if its the valve or the O2s as the problem
So I went out and pumped the four tires back up to 30#, plus a couple, just in case it got even colder.
Today, the temps were in the mid 80's and like you, I got an SES warning with the code that all 4 TPS had failed.
I found out that after having run the vette a while on the interstate, the tire pressure had exceeded 36# and kicked the sensor into default error mode, triggering an SES warning.
Let 4 pounds of air out of the tires solved the problem.
