Crank Pully??
Old Oct 19, 2005 | 03:15 PM
byte_me's Avatar
byte_me
Default Crank Pully??
Anyone change one of these? It looks like mine has a very slight wobble...I don't know how much but it looks like ever so slightly....
Does this mean it will fall off???
Old Oct 19, 2005 | 04:52 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Yes, and possibly..
I replaced mine w/ an underdrive ASP, used it as an excuse to do a cam upgrade.
Most stock pullies have a slight wooble, and as long as you keep an eye on it, it may last a while..
Or you could do what I did, and swap it, sleep soundly at night.
Old Oct 19, 2005 | 05:01 PM
byte_me's Avatar
byte_me
Originally Posted by Dan_the_C5_Man
Yes, and possibly..
Did you do the swap yourself? What was involved? Looks tight between the rack and the pulley itself...also- did you notice any voltage issues going to an underdrive pulley?
Thanks!
Old Oct 19, 2005 | 05:35 PM
Dan_the_C5_Man
No one wrenches on my car but me..
Yes, it's quite a job.. You must remove the radiator, steering rack, etc. to gain access. And if you do items like changing the crank seal (that is mated to the crank pulley, so you really should do it; this requires removing the water pump, alternator, etc.).
So now your knee-deep, 3/4 of the way into a cam install. If you ever want to do a cam, then absolutely do it while you are swapping the pulley.
No low voltage issues what-so-ever.
Old Oct 19, 2005 | 05:55 PM
vettenuts's Avatar
vettenuts
For just a pulley, do you think you need to pull the radiator? Not sure if you can get the puller on with it there, but as stated, it is not a trivial job. Its not hard though. I made my own press for re-installation and pinned the crank while it was apart.
Old Oct 19, 2005 | 06:46 PM
C6-Stingray's Avatar
C6-Stingray
Are there any VIN# that are affected?
I have a 2005 MN6 Z51
To Crank Pully??
