Question about Dyno
Old Oct 20, 2005 | 09:24 AM
glind46677's Avatar
glind46677
Default Question about Dyno
I had the LS-1 edit done on my A4 Then I changed from 273 gears sto 342 gears. Should I have the LS-1 edit done again?????
Old Oct 20, 2005 | 09:36 AM
byte_me's Avatar
byte_me
Yes- you need to let the ECm know that the gears are different or you will bounce off the rev limiter while driving at WOT. The ECM controls when the torque converter locks up and with different gears the computer will think the tranny is slipping or something...
Old Oct 20, 2005 | 10:46 AM
Blow Torch's Avatar
Blow Torch
Your speedometer will be off until you reprogram it
Old Oct 20, 2005 | 03:04 PM
G-lock's Avatar
G-lock
WRONG!! The C5 is not effected by gear changes as the reluctor wheel is on the carrier, only tire size changes mess with the speedo! Jeff
To Question about Dyno
