Problems after installing ported throttle body
Is it a Lingenfelter, Shaner or Katech throttle body? Here's a ttt for you. I'm curious myself. Good luck!
Ed
I had the same problem. The throttle body has been opened up too much. The throttle blade is set at a preset angle during startup, and it it letting in too much air. Once the PCM knows this, it adjusts the throttle speed accordingly. You have two choices, tune your cold startup sequence to set the throttle differently on cold start, or get a hold of whoever ported it and see if you can get another one. I went with the second option and haven't had a problem since.
The issue is many times the porosity in the cast aluminum. Once they open it up, there can be pitting in the aluminum and to smooth it out you can end up with the problem you have. It is more common than you might think.
I would be curious as to who ported it myself.
This may be a long shot but I pulled the shaft out and there is a tab behind the gear that works as a stop. I bent it some to allow it to go shut the same amount as my stock one. That should take care of the high rev at start up. Since I done that I thought of another problem after doing that. The throttle position sensor is going to think that the throttle is closed more than it really is and that will cause it to be more lean and have less timing so I Am going to drill the two holes just a little bit bigger in the sensor where the two bolts go so I can turn the sensor a little to compensate for the blade being shut more. That should take care of that. All of the 80s and early 90s mustangs had the adjustable sensor on them so you could do some fine tuning. So I'm going to finish modding it and see what happens. If it works like I have planned it should be good to go. I'll see what happens. I always have my stock one I could put back on.
Ed
steve
steve
steve
gojo’s Idle Relearn
C5 Idle Relearn Procedure
Purpose
This page basically shows you step by step how to do an Idle Relearn. You would want to do this if you have done any intake modifications. If you do not do this, you may have hesitation or other issues.
Tools Required
None.
Do the Job
Follow these procedures EXACTLY or you will have to start from scratch.
Insert key into ignition and turn to the "On" position but, DO NOT START THE ENGINE.
Pop open the engine fuse block box cover and remove the two 10amp fuses from position numbers 16 & 23.
Your DIC will now display "check" messages for ABS, etc...
Turn ignition to the "Off" position.
Re-insert both 10amp fuses for positions 16 & 23.
Start your engine
Allow engine coolant temperature to reach a minimum of 176 degrees F and run at this minimum temperature for at least 5 minutes.
Shut down engine
Let rest for a minimum of 30 seconds.
Restart engine - check for DIC error codes (there should be none).
Drive car for a minimum of 30 miles at varying rpm settings and speeds. PCM will now re-learn and adjust for the new air flow and air temperature at the intake.
If this doesn't work I'd send it back. You might be able to tune around it (maybe not)....but is it worth your time and effort??
Most newer fuel systems learn the TPS voltage and remember it. In the old days tuning the TPS made a big difference, but now days I don't think it makes much difference until you get too far out at which time the PCM is just going to assume the TPS is bad. Programming the TPS learn feature into the PCM firmware just takes away another thing the mechanic at the dealership can screw up. Making it kind of idiot proof. Of course if you make something completely idiot proof, they will just come up with a better idiot!
You just saved me some work. I'll go out and put it back on to see what it does.
FWIW.
After it's warmed up it idles at around 800rpm. Here is a pic. of the tab I had to bend. Doing this allowed the throttle to close more.
