gaskets for the valve covers?
Old Oct 30, 2005 | 07:27 AM
NSTG8R's Avatar
NSTG8R
Default gaskets for the valve covers?
i've been reading a bunch of header installs and people just mention bolting the valve cover back up
does the ls1 not need some goop (sealant) or a gasket or anything?
thanks,
Kyle
Old Oct 30, 2005 | 07:58 AM
vettenuts's Avatar
vettenuts
No, gaskets fit right into the valve cover and are a nice soft rubber, almost like an O-ring. Just clean everything real good. You should clean the are prior to removal of the valve cover as well so junk doesn't go into the rocker valley.
Old Oct 30, 2005 | 08:03 PM
NSTG8R's Avatar
NSTG8R
thanks.
just pick up a new set from gm? or should i go to an auto parts store .. does it matter?
Old Oct 30, 2005 | 09:33 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
I use GM, they don't cost that much, and larger Dealers usually have them in stock
Old Oct 30, 2005 | 09:35 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
reuse the valve cover gaskets; i've had dozens off and on w/ no problems; you can use the oem metal exhaust gaskets as well
Old Oct 31, 2005 | 01:53 AM
NSTG8R's Avatar
NSTG8R
planned on reusing the exhaust one .. but the one for the valve cover meeh i dunno that's kinda one of those items i'd replace for the extra ten dollars.
Old Oct 31, 2005 | 07:12 AM
SteveDoten's Avatar
SteveDoten
no need, talk to the big tuners across the country, but if you choose to replace them no big deal, like you said 10 bucks
Old Oct 31, 2005 | 02:51 PM
NSTG8R's Avatar
NSTG8R
thanks.
Old Oct 31, 2005 | 05:14 PM
M_T_0's Avatar
M_T_0
just did a cam and heads on 90k mile engine the valve cover gaskets were fine, I had mine off to polish the covers and I would not recomend replacing them unless you see signs of damage, they are a PITA to get back on the covers. just clean and reinstall.
More Than Zero
Old Nov 1, 2005 | 04:13 PM
FKING1's Avatar
FKING1
Mine were stretched after taking off and would not seat properly in the groove when trying to reinstall. If the old ones fit in the grooves, reuse, otherwise get new. No goop!!
Fred
Old Nov 1, 2005 | 06:02 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
My valve covers have been removed a few times and now they are seeping oil.
I guess it's time to replace the gaskets.
To gaskets for the valve covers?
