harmonic balancer
Old Oct 30, 2005 | 03:18 PM
jakestyr's Avatar
jakestyr
Default harmonic balancer
I have a wobble in my balancer pulley.2000 vert.50000 mi. Is this a common problem?Sounds like it could be serious.I just changed the tensioner & belt and noticed the wobble. No vibration!
Old Oct 30, 2005 | 04:40 PM
babalu95's Avatar
babalu95
Default Balancer
Had mine replaced last year. THe GM tech said it was one of the most common problems in C5s. I had a squeel which we assumed was coming from the belts or tensioner. He showed me in spite of no vibration how it was wobbling under a light. I chose to go with a factory parts.
Old Oct 30, 2005 | 10:32 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Don't ignore this.. Folks have lost entire motors over failed balancers.. Go aftermarket so you don't have to worry about it again.
Old Oct 31, 2005 | 04:00 PM
mrtoner's Avatar
mrtoner
What fails, and how is the motor damaged?
Old Oct 31, 2005 | 04:19 PM
CORVETTE CRAZY 2's Avatar
CORVETTE CRAZY 2
Ttt
Old Oct 31, 2005 | 04:20 PM
CORVETTE CRAZY 2
And What Are The Benefits Of Going After Market
Old Oct 31, 2005 | 04:25 PM
CORVETTE CRAZY 2
Mine Is Also A 2000 VERT With 83,000 Miles On It Started About 5,000 Miles Ago
Old Oct 31, 2005 | 08:47 PM
Dan_the_C5_Man
The pulley coming apart, moving back toward the block, wiping out the front of the motor / oil pump, etc.
Ask "Subdriver", he'll tell you his tale.
Old Nov 1, 2005 | 11:03 AM
CORVETTE CRAZY 2
Old Nov 1, 2005 | 12:07 PM
vettenuts's Avatar
vettenuts
The steering rack is also about a bazillionth of an inch in front of it. The C6's were having problems with the bolts backing out, taking out the steering rack, spraying PS fluid everywhere. From what I read, the fix was a new balancer, bolt, steering rack and paint job on the car
To harmonic balancer
