I'm looking at adding an X pipe to replace the stock junk H pipe. I know you can buy the complete MagnaFlow X pipe section but it's alot of money compared to just getting the X pipe and have it welded in. Has anyone here done this before? Is the spacing between the pipes the same as the Mag. X pipe? If you look at the cost difference, the complete X pipe section is over $265 and just the X pipe is $80.
The only problem with just welding them in is the old rust problem. I have not looked lately, but Summit used to have the weld in type x-pipes for a reasonable price. The original ones, the ones used in NASCAR, were made by Dr Gas. He has a web site you can reach through a Google search.
From what I have seen some are stainless steel and some are aluminized. The good ones are stainless steel and that is what cost more. If you buy just the X pipe then have it welded in you still have the rust issue with the weld I think. When you add the labor to get it installed your probabily going to be around $200 for the system installed.
Hey Neablas: the only problem I see with yours will be the shipping cost because it's so big. Good price besides that.
