6 Speed Shifters - Which one?
Old Oct 31, 2005 | 06:25 PM
Black 79's Avatar
Black 79
Default 6 Speed Shifters - Which one?
I want to put an aftermarket shifter in my '00. There are several good ones on the market; in the Ford world, the Pro 50 is arguably the best, but it is not available (as far as I know) for C5s. Which one would you recommend?
Also, my car is popping out of reverse. I hope the aftermarket shifter will fix it. It acts as though it is not engaging all the way and pops out if I don't hold the shifter while backing up.
David.
Old Oct 31, 2005 | 06:40 PM
arzee2's Avatar
arzee2
If it's popping out of gear, it could be a synchro. My 92 LX Stang had the same problem in 2nd gear. Just a thought. Hope it helps
Old Oct 31, 2005 | 06:54 PM
DRKCYDE's Avatar
DRKCYDE
Cruise-In VII & IX Veteran
Dont waste your time with the C6 ZO6 shifter. If you want that route, just cut and bend your stock shifter. It isnt worth the $190 to have the same throw and mechanics.
If I could do it over, I would go with the B&M Ripper.
Old Oct 31, 2005 | 07:41 PM
vettenuts's Avatar
vettenuts
Interesting, because I really like my C6 shifter and ****. I had the Hurst and pulled it out after a week, couldn't stand it or the noise I got with it.
Old Oct 31, 2005 | 07:59 PM
9T3JIM's Avatar
9T3JIM
You may want to consider the B&M sport shifter, I believe the part # is 45044. Very positive shifts and a short throw. At first, the shifts took a little muscle but after 500/600 miles it has loosened up and is a lot of fun going through the gears.
Old Oct 31, 2005 | 08:03 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Love my Hurst! No matter which one you get, it is an easy install.
Old Oct 31, 2005 | 08:45 PM
JPEAK's Avatar
JPEAK
Old Oct 31, 2005 | 10:06 PM
SGT. PYLE's Avatar
SGT. PYLE
HURST IS THE BEST!!! Dont waste your money on anything else.
Old Oct 31, 2005 | 10:19 PM
muncie21's Avatar
muncie21
My wasted money is on a Kirban. Like it much better over stock. Although for those with 'challenged' wrist muscles, it may take some getting used to
Old Oct 31, 2005 | 10:40 PM
ST0CKER's Avatar
ST0CKER
ditto, went from hurst to c6 and love it. and I drag race ALOT, never miss any gears w/ it and can shift very quick still.
Dave
Old Oct 31, 2005 | 10:45 PM
DRR's Avatar
DRR
Only have my stock C5 to compare to, but I like my C6 alot. That is my vote. Also, it sounds like you have trans problems.
Old Nov 2, 2005 | 12:33 AM
Black 79's Avatar
Black 79
I am still hoping that the popping out of reverse is linkage related and not the trans. I haven't seen any pictures or diagrams of how the shifter makes connection with trans so I am still hoping that the linkage can be adjusted somehow.
David.
Old Nov 2, 2005 | 05:32 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Hurst and I love it! I might go to a softer sping just for giggles but I love it atthe track. I am using the OEM **** too asI like it better than the aftermarket one I tried.
Dave
Old Nov 2, 2005 | 05:42 AM
chiefDave's Avatar
chiefDave
David.
Could be stock shifter has gone off ceneter, but this is normal with an aftermarket shifter if not aligned corectly. Happened to me :o If you install one with adjustabe stops, take themout to be sure o at least lock tight them. That would casue a 1,3,5 or 2,4,6 issue. R being farthest could be an alignmet issue. Lots of these cars like to go from 3rd to R or 2nd to R (from a stop before going into R...). Good luckl!
Dave
Old Nov 2, 2005 | 06:38 AM
QKSLVR Z's Avatar
QKSLVR Z
another vote for Hurst!
Old Nov 2, 2005 | 07:46 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I have used all 3 shifters (C5 stock, C6 Stock, and Hurst). To be honest the only one that suxs is the C5 stock. The C6 and the Hurst have much shorter throws.
The C6 shifter takes much less effort to move over the Hurst. I liked it, but for slamming gears I thought the Hurst would hold up better plus finding 3rd and 4th is never an issue. If you are in traffic alot or if you have a wife that drives the car I would consider the C6 shifter over the Hurst (no offense to women, but I talked to a handful of people and most say that their wives dont like the Hurst because of the additional effort it takes to shift).
Old Nov 2, 2005 | 11:23 PM
Black 79's Avatar
Black 79
The new B&M sounds interesting (no buzz, short "click" throws) but I like the adjustable stops. I have a couple of Mustangs with the Power Tower Pro 5o shifters and they are bullet-proof with no buzz. I guess the distance between the shifter and the trans magnifies the vibration in a C5 and makes the buzz noticable without rubber isolators.
Does the Hurst have stops and does it Buzz?
David.
To 6 Speed Shifters - Which one?
Old Nov 2, 2005 | 11:33 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
My wife has no problem with the Hurst and I even shortehed it an additional .5 in. and bored the cueball **** out so it is very short. Have never missed a shift to any gear and have had it for 3 or 4 years and it has held up over many hard power shifts.
cheers
Old Nov 2, 2005 | 11:42 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I also love my Hurst shifter and have had it for 3 years and like it even better after going FI, need the shorter shift
Old Nov 3, 2005 | 12:34 AM
Black 79's Avatar
Black 79
Does the Hurst have adjustable stops and does it Buzz?
