Will no CATS on a C5 drastically affect emission readings?
Just interested if anyone is running a no cat system on the street that is still DMV legal with respect to emissions?
TIA...
BC
If they do a tailpipe sniffer test, your toast.
Here in Connecticut they only do an OBD2 download so if you go to the right place (where the inspector won't question the exhaust smell) you can usually get by.
Hope that helps.
But, depending on the type of emissions test/inspection you have, you can still pass.
My state only does the OBDII computer system check, they do not sniff the tailpipe, nor do they visually check for cats or anything. My car flies thru and passes with no cats.
If a sniffer test is involved, there is still chance you could pass it. Yes, people have done it before. This just goes to show how unnecessary cats have become on modern computer-controlled engines, these cars can run clean enough to pass a sniffer even without cats. Imagine that.
If there's any sort of visual inspection, you will obviously fail that, unless you simply gut a set of cats or better yet, run a straight pipe through the cat housing.
But the bottom line is, even if you sneak it through an emissions test, doesn't mean it's legal.
US guys...thanks for the feedback...CATS it is
Its a nice ceramic coated system from the headers to muffler hook up as well.
BC
My Z06 has supercharger, bigger injectors, LT headers and no cats and it passed Ca smog testing. It is who tunes your PCM that makes it pass or not.
My tuner had me go for a smog pretest which was tailpipe while in a threadmill. He wanted me to use my PCM scanner and have it in record mode during the test. A pretest is not counted against you if you fail.
I then emailed the scanner recording and the smog test results ( which car failed at that time) which he analyzed
JR then did a custom tune which he emailed me which I flashed in and waited until PCM relearned and then went back to same smog test station and car passed !
As long as the tuner knows what they are doing and what the tailpipe exhaust makeup readings are they can get the engine tuned so that the exhaust makeup is correct without having CATs.
If station of course did a visual then car would fail but how many smog stations jack a car up and even look ?
and his "Silent but deadly" routine...smells a bit like
He only has the PCM 1 day if you mail it to him but you need to give him a complete list of changes made to car, what smog tests your county does and best case is if you can email him a PCM scanner recording so he knows exactly what changes needs to be special to your car.
I have had 2 friends also with superchargers and in Ca that used JR and their C5s also passed smog without cats.
