Front speaker questions....PLEASE HELP
This is the head unit I bought.
www.cardomain.com/item/KENKDCMP5028?vq_id=none
Maybe not the nicest in the world but it got very good reviews so I don't think it's the problem (although I don't really know).
I do not have a separate amp. I didn't think I needed one but I don't really know that either. To be honest, I'm not exactly sure how the factory audio set-up worked and I don't really know what they did when they put the new stuff in. I just know it sounds really terrible.
If anyone has some suggestions/advice for me I'd really appreciate it.
http://forums.corvetteforum.com/show...59&forum_id=20
http://www.subthump.com/
I was told that the good quality sounds come from the speakes and the amps. As I am a poor cop and dont have thousands of $'s to spend on sounds, I have to shop for the best I can get for my budget.
Here is what I did....
I left the delco HU (CD Player).................free
PAC Vet1 interface for RCA outputs...........$65.00
Infinity 3002cf 3.5" fronts.......................$49.00
Infinity 6002si 6.5" 2 way rear..................$79.00
Factory Bose door woofers......................free
Fosgate 201S, 200w amp........................$99.00
Kicker 03C12 12" Sub.............................$79.00
Subthump Custom 12" sub-box................$182.00 shipped
Amp install kit..................................... .$20.00
So as you can see I have spent less that $600.00, and let me tell you..this this freakin rocks!! The sound is very clean and I used the great information I found on this forum to install it all myself. (removing door panels, stereo trim, wiring, etc....)
The bass hits so hard in this thing that my wife says it makes her stomach hurt. You can litterally feel it in your bones. I listen to real rock and roll...AC/DC, Sabbath, Zepplin, etc...and there nothing like having that driving kick bass drum shot through you like you were sitting right in front of it.
I will tell you another thing, I installed the door and rear speakers while I was waiting for my sub box to be made and just replacing the stock 3.5's and 6.5's made a night and day difference.
Good luck and if I can help with any stereo install ?'s please feel free to ask. I also found a trick Sirius receiver mount for the C5 and good antenne mounting option.
In each front door there is a 8" woofer and 3.5" speaker.
In the doors you left the 8" woofer but replaced the 3.5" speaker.
The back speakers are 6.5" speakers and you replaced them.
In addition to this, you also had a 12" sub installed.
Did I get all this right? And as far as the amp, did you get the amp because you were getting the 12" sub or did you want it anyway? I really don't even know anything about amps because I've never had one before. To be honest, I don't even know where the amp goes or how it hooks up to everything else. If you don't mind explaining some of this in a little bit more detail, I'd really appreciate it. Thanks.
The idiots from Best Buy should've been able to let you use your new HU with the Bose speakers. You just needed an interface to go from the HU to the Bose speakers, most people that do this use this
Click for Soundgate interface
TJ
I did leave the factory Bose 8" subs in the doors as well as leaving factory HU. The Bose subs have their own amps. The factory HU supplies power to the door 3.5's and the rear 6.5's. The 3.5 and 6.5 factory speakers are "full range" speakers that sound ok but not good quality. (especially in the high range).
I just disconnected the factory speakers and plugged in the new ones with the same wires. (These speakers are plug and play replaceable, powered only by the Factory HU).
As I stated in the previous post, I had a custom 12" sub enclosure made and added a Kicker Comp. 12" sub that sits in the center storage compartment. The amp I installed is a Rockford Fosgate 201S (200 watt RMS). This amp comes with a verification certificate and states that the amp is actually putting out 263 watts rms.
This amp only runs the 12" sub. In order to connect the sub to the existing system, I purchased a PAC-VET1 wiring harness that plugs in in-between the factory HU and the factory wiring harness (no cutting or splicing) and provided four RCA outputs. (2 left, 2 right) So all I had to do was run an RCA from this harness to the back of the car and a power and ground from the battery.
I mounted the amp on the flat panel in the back of the car (just above the center storage compartment where the sub is located.
The whole install took just a few hours and I did all myself. It was really pretty easy. I will be happy to help you out any way I can. My email is txcop2000@ev1.net. Good luck and I hope this helps!
lists service bulletins for door noises in the interior section.
http://www.corvetteactioncenter.com/...ry.php?catId=6
HTH
You will get there, but you will have to spend a little more $$. (its worth it though!!)
I have a Z06 and I want to install a single "SMALL" base speaker 10" and a smaller amp. I need that spare tire area and dont want to fill it up with base box. I want to construct a sealed box that will fit into the the area on the left or right side of the trunk. Then I want to replace the door speakers and the rear speakers. The rear speakers in a Z06 are smaller than the Coupe. What is the size of the stock speaker and can I cut the enclosure hole and add a BIGGer rear speaker in the same enclosure area???
bill C
bill C
I have finally come to a conclusion on what I am doing with the sound system in my car. At first I was going to try to take the cheap way out, but I love my vette too much to do that. So I took it to a Tweeter store and started talking to someone there. Well, to make a long story short, the guy there convinced me to take out the cheap stuff I'd had installed, return all of it, and put a VERY nice sound system in (completely replacing all factory equipment). It is going to cost me some serious money but I got financing, so who cares?
So here's what I'm getting installed:
HEAD UNIT:
Alpine CDA-9851
SPEAKERS:
In the doors: JL-Audio XR650-CSi (6.5" 2-way components)
The rears: JL-Audio XR650-CXi (6.5" coaxials)
In the back storage space: Custom fit stealth box with JL-Audio 10W3D2 (10" sub).
AMPS:
For the speakers in the doors and the rears: JL-Audio 300/4
For the 10" sub: JL-Audio 500/1
This is going to be a hell of a system and I'm sure in the end, it will be well worth the money.
I do have a few questions though to anyone who has already done a stereo system upgrade:
Has anyone put in the Alpine CDA-9851 and if so, were you happy with it? I know the JL speakers and amps I'm having installed are great quality but wasn't quite sure what head unit to go with.
Also, any recommendations for where I should have them mount the amps? They said it's pretty much up to me but I wasn't sure.
And lastly, I saw a forum discussion where a couple members were discussing the potential problem of their amps overheating. Has anyone had this problem? Should I be worried about this?
Looking forward to feedback. Thanks.
(Oooops...didn't see your recent post about taking out the entire system. Hope it all works out for you.)
