Help Needed!!!
Old Nov 5, 2005 | 04:54 PM
YELLOHHH's Avatar
YELLOHHH
Default Help Needed!!!
P 1220 & P1221.
Codes will NOT clear. Car stays in reduced power mode and is undriveable. Has happend a few times in the past, but was very random. WHAT DO I DO???
Old Nov 5, 2005 | 09:10 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Check these links out, should be of some assistance..
http://gearchatter.com/viewtopic1015...45f4545d731358
Old Nov 6, 2005 | 07:58 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
You have a Magnacharger, right?
When the Magnacharger is installed the harness for the throttle position sensor has to be lengthened, check the connections where the harness was cut and spliced, I had to go back and redo one of my connections a couple months after I installed my supercharger.
Old Nov 6, 2005 | 02:41 PM
YELLOHHH's Avatar
YELLOHHH
I have had these connections redone, and soldered, so I'm pretty sure it's not that. I'm going to take the TPS off, and perhaps the throttle body and give everything a good cleaning and see what happends.
Dan, thanks for the threads, I'll go throught them the best I can.
Anyone else deal with this exact problem?
To Help Needed!!!
