Paint Chip Repair
Old Nov 8, 2005 | 03:11 PM
Digmo's Avatar
Digmo
Default Paint Chip Repair
OK, I got my 2004 vert to drive and enjoy very much. But I now have a couple of stone chips in the hood that a bra would not have protected. Being new what is the best way for diy to repair?
All advice welcome
Ray
Old Nov 8, 2005 | 03:46 PM
Ebbsnflows's Avatar
Ebbsnflows
All advice welcome
Ray
Take some fine grit sandpaper (2000 grit) and use a "hole punch" to punch 10-15 holes in the sand paper. Take the "sand holes" and glue them to the eraser on a pencil.
Take the sanding-pencil and place the eraser/sand paper on the ding. Gently TWIST the pencil between your fingers , rolling it back and forth. that will allow you to sand a very specific area without scuffing the good paint that surrounds the ding. Once you've "scuffed/sanded" the rock ding, use some alchohol and clean the chip thoroughly.
Get your favorite rock chip/touch-up paint (from the dealer or wherever) and then grab a TOOTH PICK. Dip the toothpick into the paint and get a nice little "tear drop" of paint on it (nothing HUGE, just a nice tiny little droplet) Gently and carefully hold the tear-droplet of paint near the rock chip. The natural physics of the paint will cause the droplet to "grab" onto the rock chips surface making a nice smooth "fill in". Carefully pull the tooth pick away. It should leave a slightly raised bubble on the vehicle. That's fine. Leave it be. Now go ahead and repeat for the remaining rock dings. Let the paint dry (based on recommended drying times on the paint label) or you can use a hair dryer to expedite the drying.
Once the paint is COMPLETELY dry. It's time to pull out your "sanding pencils" again. Using the same technique as before, use the eraser/sandpaper to gently sand down the contour of the touch-up paint. As I said, place the eraser onto the newly repaired, and slightly contoured paint and GENTLY twist the pencil back and forth between your index finger and thumb. That will server 2 purposes. It'll smooth out the excess paint, making it flush w/ the good paint and it will help prep it for the clear coat droplet that you're going to add.
Once you've sufficiently sanded down the excess touch up, use the alchohol to clean the area once more. Now it's time for the clearcoat.
Using a very sparing amount, go thru the exact same process as above. After the clearcoat is dry, gently sand, and clean w/ alchohol.
Now you're ready to apply your Zaino (or whatever car care product you use). I recommend practicing on some of the less conspicuous chips first in order to get your technique down. But after a couple of practice dings...you'll be ready to make her look as good as new.
Old Nov 8, 2005 | 05:32 PM
Last Mango's Avatar
Last Mango
Very informative for those of us who are paint challenged. Thanks.
Old Nov 8, 2005 | 05:42 PM
jers98vet's Avatar
jers98vet
You'll end up with a virtually invisible repair especially if your car is a solid color.
Old Nov 8, 2005 | 06:51 PM
Dirty Howie's Avatar
Dirty Howie
ebbsnflows:
Very nice write up
A couple of questions:
1. what glue sticks to a rubber eraser
2. where do you get a small bottle of clear coat
DH
Old Nov 8, 2005 | 07:31 PM
C5XTASY's Avatar
C5XTASY
Wish that were true of pewter...
Ed
Old Nov 8, 2005 | 08:36 PM
RoHo's Avatar
RoHo
Finger nail polish
Old Nov 8, 2005 | 08:59 PM
WNeal's Avatar
WNeal
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
Some great info thanks
Old Nov 9, 2005 | 11:29 AM
Ebbsnflows's Avatar
Ebbsnflows
Originally Posted by Dirty Howie
ebbsnflows:
Very nice write up
DH
Dirty-
1. You can use any popular brand of rubber cement available in the office/school supply section at W-mart or even some good ol' Elmers. Just add a tiny droplet to the smooth back section of the Sanding-holes and "stab" it w/ the pencil eraser. You probably only need 3-4 pencils. Once the sand paper has expired (lost it's abrasiveness) just peel it off the eraser and apply another sanding-hole to it.
2. I've seen Clear-coat touch up sold right along side the touch up paint. If your dealer doesn't have it, try Autozone or Pepboys (or any other place that sells touch up paint). For the most part, "clear coat" is pretty standard and not vehicle-specific.
I'm sorry if my "How to" is confusing. But it's really not complicated. It's basically just using the right house-hold items and applying some common sense more than anything.
Old Nov 9, 2005 | 12:37 PM
ken-rx's Avatar
ken-rx
I'm saving this one, great techniques.
Old Nov 9, 2005 | 01:09 PM
DBRASUE's Avatar
DBRASUE
Excellent write up! I'll try it if and when I get a chip!
Old Nov 9, 2005 | 01:19 PM
Digmo's Avatar
Digmo
Default Thanks
Thanks again for your help. I think that I am now more confident to try a chip repair myself. A big forum thanks to Ebbsnfllows for hi help.
Ray
Old Nov 9, 2005 | 03:55 PM
Dirty Howie
Originally Posted by Ebbsnflows
Dirty-
Your how to is not confusing at all...you did a great job. And I intend to try it on some of my paint chips
DH
Old Nov 9, 2005 | 04:31 PM
C5XTASY's Avatar
C5XTASY
If you drive much, it's like dying, it's not a matter of "if", it's matter of "when".
Ed
Old Nov 9, 2005 | 04:39 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Dirty-
Good stuff except Have your touch up mixed (tint matched)at the body shop.
The Color match touch bottles, are junk and don't match well and will show .
Old Nov 9, 2005 | 06:37 PM
BlackVettesRBest's Avatar
BlackVettesRBest
Very nice write-up. Thanks.
Old Nov 10, 2005 | 06:32 PM
Digmo's Avatar
Digmo
Default paint chip repair
ttt
To Paint Chip Repair
