Replacing shocks in 2002, how difficult?
Old Nov 8, 2005 | 07:26 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Replacing shocks in 2002, how difficult?
Don't have a manual. can anyone talk me through front and rear shock replacement
I am a C4 guy, where you can see everything
Jack
Old Nov 8, 2005 | 09:03 PM
vettenuts's Avatar
vettenuts
Torque on rears is quite high. On the fronts, you need to compress the shock and hold in the compressed position both to remove and install.
Old Nov 9, 2005 | 07:14 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Thanks!
Do you need a "spring compressor" or similar tool?
When you say torque is high, high?
If you are simply replacing brake pads at the same time, can you get to the shocks without removing other stuff?
Jack
Old Nov 9, 2005 | 07:57 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Here ya go Jack!
http://fuzzydiceracing.com/test.htm
Old Nov 9, 2005 | 10:43 PM
tsts's Avatar
tsts
[QUOTE=jackdaroofer]Thanks!
I used a wire coat hanger to hold the shock compressed both in and out, some people use cable ties (two sets per shock because one set sometimes doesn't hold). Job went easy both front & back usinga floor jack (and stand) and one wheel at a time.
Old Nov 10, 2005 | 07:40 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Originally Posted by 03Ragtop
Thanks!
Is that "fuzzydice" down in Fla?
Will we seeya at cruise in VII?
Jack
To Replacing shocks in 2002, how difficult?
