04 PCV Questions
Old Nov 9, 2005 | 11:19 AM
04BlueGoose's Avatar
04BlueGoose
Default 04 PCV Questions
Want to put a catch can on my 04. Is the pcv in the same place as earlier years? Do I need to do anything different for the line hookup?
Old Nov 9, 2005 | 01:16 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
The PCV line comes off of a nipple at the front of the valley pan right below the neck of the intake manifold on the passenger side. The line is only a couple of inches long cause it basically connects to the intake manifold directly above it.
You can route the line from the PCV to a specific mounting point of the catch can, then back to the intake manifold.
Hoope this helps.
Jeff
Old Nov 9, 2005 | 02:51 PM
wolfman04's Avatar
wolfman04
Hoope this helps.
Jeff
Do you have any pics that you can post?
Old Nov 10, 2005 | 09:48 AM
04BlueGoose
Hoope this helps.
Jeff
Thanks for the help Jeff
To 04 PCV Questions
