Charge System Fault???
Old Nov 14, 2005 | 08:30 PM
ElanMike's Avatar
ElanMike
Default Charge System Fault???
Over the last couple of months, I have received a 'charging system fault' message a number of times. After I get the message, the system voltage drops to 10V. Sometime later it corrects itself. On one occasion, this was followed by an 'Over Voltage' error and the system was outputting 16V!
I'm assuming this means it is time for a new alternator? Is there some other circuits I should look at before I drop $350 on a new alternator? Is a repalcement AC Delco unit the best choice, or should I look at another brand?
I have a new audio system which can suck up to 60A peaks so I figured I might get the 145A AC-Delco instead of the stock 110A. Any comments?
Appreciate the feedback
Old Nov 14, 2005 | 10:03 PM
rws.1's Avatar
rws.1
Take it to a major autoparts store....they will run a fress charging system diagnostic in less than 5 minutes with the battery in place.
If it is the alternator, you can buy a new alternator from them for $168 and swap it out yourself.
Just unplug the connector, loosen a couple bolts , and put the new one in place. the tensioner is automatic... its a 10 minute job max.
Old Nov 14, 2005 | 10:09 PM
rws.1's Avatar
rws.1
That should have read free diagnostic
rws.1's Avatar
rws.1
Old Nov 15, 2005 | 04:38 PM
craig04c5's Avatar
craig04c5
I just got that message in my 04 with just 9300 miles today just after I started it then the message dissapeared. Is this normal?
Old Nov 15, 2005 | 06:25 PM
Sportsdude's Avatar
Sportsdude
You might want to check the grounding cable. I received the same message in the past and once I tighten the ground cable, no more error code.
Old Nov 15, 2005 | 08:22 PM
Joe's Eray's Avatar
Joe's Eray
Where is the grounding cable?
Old Nov 15, 2005 | 09:09 PM
David426's Avatar
David426
i got a charging system failure alert on my DIC too a few months ago. had it tested. No problems. Just a freak pop up I guess
Old Nov 16, 2005 | 08:29 AM
craig04c5's Avatar
craig04c5
That's what I was hoping it was.
Old Nov 16, 2005 | 05:41 PM
2003vert's Avatar
2003vert
Had the same problem on my 03 the message would appear then clear itself, the dealer could never find a problem. As it was under warranty at the time the dealer replaced the ignition switch. No problem from that time. From other posts on this form it is a good bet that it is a ground problem somewhere.
Old Nov 27, 2005 | 02:42 PM
p-51dquest's Avatar
p-51dquest
1st Gear
Default having the same problem
i purchased a new a 2004 corvette conv.-6spd-(2-15-04) i have 2031 miles and for the last month i've experienced the display of "charge system fault" when i would start up (only time it displays message) 3 out 10 times i see that other corvette owners have the same problem--is there a fix to this or are we going to have a recall-- the dealership is aware of problem without any solution
Old Nov 27, 2005 | 05:12 PM
R&D's Avatar
R&D
Try checking the connection at the alt. before you do anything else.
Next I'd check all the grounds by disconnecting them and cleaning them. A simple wiggle test won't work, clean them.
Also, how old is your battery? I've seen some strange things happen in these cars when the battery is headed south.
Old Dec 5, 2005 | 03:55 PM
ElanMike's Avatar
ElanMike
Default Charge fault - 10V, 9V, 8V, Dead!!
Well, after months of having no more issues, yesterday I took the car our on CA Hwy 1. 2 hours in to my drive, half way between Carmel and Big Sur, I got a 'Service ABS' message. This was followed a few minutes later by a 'Service Stability control' message. I decided to turn around and head home. Then came the 'Charge System Fault' message again, after which I got to watch the voltage count down - 9.8V, 9.6V.... 8V. Then the guages stopped working. I was still on Hwy 1 in the middle of nowhere. The engine was still going but started choking going up the hill - the fuel pump had stopped. I pulled over, no cell coverage! Luckily someone else pulled up and drove me to a store. The AAA towed the car and it is now in the Chevy Dealer in Seaside waiting to be diagnosed.
I'm thinking this points more to the Grounding issue as apposed to the alternator as I don't see why the other modules would have flagger errors first.
To Charge System Fault???
