crank pullie
Old Dec 4, 2005 | 09:17 PM
crazygn's Avatar
crazygn
Default crank pullie
is it true that a after market crank pullie on these cars are good for about a 10th off your 1/4 mile times. If so how much do they run and where can i check them out.
thanks
Old Dec 5, 2005 | 02:53 AM
diviniti's Avatar
diviniti
St. Jude Donor '05
I dont know about the 10th off 1/4 time, but I do know an aftermarket pulley that is the solid type is bad for the motor.
Old Dec 5, 2005 | 08:27 AM
byte_me's Avatar
byte_me
why is it bad?
I just bought an ASP underdrive pulley to have my wabbly one replaced...the stock unit looks like its walking off the crank (nothing can be worse then this)
Would like to know what and how it could be bad?
Old Dec 5, 2005 | 08:52 AM
vette747's Avatar
vette747
There is no rubber ring to absorb the vibrations. The vibrations are transmitted to the crank and engine. And might cause problem to the crank bearing. Like having an un-balanced wheel tire assembly could be bad on the wheel hub.
Old Dec 5, 2005 | 08:57 AM
byte_me's Avatar
byte_me
From the looks of it - the ASP pulley I have has a large snap ring on the front outside of the pulley face with what looks like a rubber compound...I could be wrong...
Old Dec 5, 2005 | 09:00 AM
vette747's Avatar
vette747
Then, this is not a solid type. But I have never seen an ASP.
Old Dec 5, 2005 | 01:23 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
No, you are correct. ASP pulley (and ATI, Power Bond, etc.) are built similar in concept to the factory unit.
Old Dec 5, 2005 | 01:27 PM
byte_me's Avatar
byte_me
Sweet!
$209 + Shipping from Summit Racing Online...
Thats about $50 less then every where else!
Old Dec 5, 2005 | 04:11 PM
diviniti's Avatar
diviniti
St. Jude Donor '05
^ what he said.
Old Dec 5, 2005 | 04:15 PM
George V's Avatar
George V
Is it worth the extra $$$ to go with the ATI Super Damper?
To crank pullie
