Move MAT sensor?
Old Nov 16, 2005 | 06:52 PM
BORLA BOY's Avatar
BORLA BOY
Default Move MAT sensor?
Just got a power duct and they say to drill a 11/16 hole for the MAT. First of all I dont have that size What is it close to? and they said you could move the MAT were should I put IT. Please tell the correct place to put it... My wife already told me were to put it, but that might hurt a little ...
Old Nov 16, 2005 | 08:35 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It has to be that 11/16's size, it will leak if it is not the right size. Move it as far away from the engine as you can, and closer to cooler air, IMHO
Old Nov 16, 2005 | 08:55 PM
Face's Avatar
Face
You can relocate it to your airbox where your AIR pump supply hose goes.
Old Nov 16, 2005 | 08:58 PM
NSTG8R's Avatar
NSTG8R
what does the air pump supply hose do anyways? where does it supply air too?
Old Nov 17, 2005 | 08:11 AM
C5XTASY's Avatar
C5XTASY
True, or if you have a Blackwing air filter, the 1997-2000 C5s can relocate to the flow gauge hole in the Blackwing. I've read that Lingenfelter does that.
Ed
Old Nov 18, 2005 | 11:34 AM
DngrZne's Avatar
DngrZne
It intakes air for the AIR pump. I believe AIR stands for Air Injection Reactor, and the purpose is to inject air into the exhaust manifolds upon startup to allow the cats to warm up faster and reduce startup emissions. You can usually hear it cycling on and off for a few minutes when you start the car up cold.
Chris
Old Nov 18, 2005 | 11:55 AM
lost's Avatar
lost
I relocated to the filter on my Halltech stinger
To Move MAT sensor?
