Kooks Paper Gaskets--good/bad?
Old Nov 16, 2005 | 08:36 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default Kooks Paper Gaskets--good/bad?
i installed 1 7/8" kooks back in march on an '02 z06, i used the supplied paper header gaskets; after 9k miles there seems to be a small leak, i plan on swapping in the oem gm steel gaskets on friday, anyone else have this problem?
Old Nov 16, 2005 | 08:38 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
I used the factory ones and don't have any problems. I heard the supplied paper ones were not that good.
Old Nov 16, 2005 | 10:04 PM
98Pace6sp's Avatar
98Pace6sp
Same, I used factory metal gaskets. No problems, no leaks.
Old Nov 16, 2005 | 10:25 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
hey steve, i used new LS1 factory gaskets w/ mine. no leaks
Old Nov 16, 2005 | 10:40 PM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
I had a small leak on mine after 5k using the Kooks paper gasket. I had the headers tightened and it solved the problem. I recently got a set of AFR heads installed and replaced the gaskets with the factory ones to be safe.
Old Nov 16, 2005 | 10:48 PM
chriswtx's Avatar
chriswtx
I used factory Fbody LS1 gaskets(the round ones) for the 1 7/8" headers. No leaks here..
Old Nov 16, 2005 | 11:17 PM
CrazyChris's Avatar
CrazyChris
I used the crappy kooks paper gaskets. They lasted all of 2K miles before a few leaks sprung up. Don't waste your time with them. They are a pain to scrape off afterwards.
Old Nov 17, 2005 | 07:08 AM
vettenuts's Avatar
vettenuts
Same here, that is what Barry from QTP recommended and they are perfect for headers.
Old Nov 17, 2005 | 10:10 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yep, reused the factory gasket..............
Old Nov 17, 2005 | 07:31 PM
REDLYNER's Avatar
REDLYNER
Wow.... I'm glad I found this thread! I just installed mine this past weekend and I have a leak. Frick'n sucks. I have a loud ticking coming from my engine. I found where there was a carbon deposit on the head, so I tightened it up. The ticking isn't as loud now, but it is still there.
I'll try our the factory ones and report back.
Old Nov 17, 2005 | 08:02 PM
SteveDoten's Avatar
SteveDoten
i'm swapping the gaskets friday oem steel, hopefully the paper is not a pita to clean off the heads
Old Nov 17, 2005 | 09:00 PM
scaperman's Avatar
scaperman
I'm going to buy the 1 7/8 kooks headers this winter any other advice besides use the original gaskets
Old Nov 17, 2005 | 09:05 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Some preimptive anger management classes!! They are a b!tch to put on!!
Old Nov 17, 2005 | 09:11 PM
chriswtx's Avatar
chriswtx
Pain to install. And the original C5 gaskets are oval and dont work with 1 7/8" headers. Thats why you need Fbody LS1 gaskets, they are round....
Old Nov 17, 2005 | 10:01 PM
SteveDoten's Avatar
SteveDoten
urban legend about the fbody gaskets, all the 97-00 c5's used round gaskets, i've got a stack of them from header installs///also think about the oval gaskets not fitting??? if it's an 01-04 which use the ovals, then the head port will match the oval gasket so wether you use round or oem oval it doesn't matter, you are sealing TWO SURFACES
Old Nov 17, 2005 | 10:05 PM
REDLYNER's Avatar
REDLYNER
Will my stock LS6 gaskets work with my 1 3/4 kooks?
By the way, on the install, here is my story! It is still on going, but it was worth it.
http://forums.corvetteforum.com/show...7&page=1&pp=20
These things are high quality, sound amazing, and give immediate SOTP hp!
Old Nov 17, 2005 | 10:06 PM
chriswtx's Avatar
chriswtx
On my 04 the oval gaskets wouldn't come close to sealing the 1 7/8" headers...
To Kooks Paper Gaskets--good/bad?
Old Nov 17, 2005 | 11:55 PM
edensknight's Avatar
edensknight
Replacing with new "factory gaskets" is the best way to go, and, preferred over the mere (Kooks supplied) leaky "paper" gasket.
Old Nov 18, 2005 | 12:22 AM
SpinMonster's Avatar
SpinMonster
Old Nov 18, 2005 | 05:41 PM
scaperman's Avatar
scaperman
Thanks this thread will be a big help when i install
