Exhaust question, gaskets. help:)
Old Nov 17, 2005 | 09:36 PM
604_c5's Avatar
604_c5
Default Exhaust question, gaskets. help:)
I got the B&B Exhaust for my 2000 convertible.
took it to the shop. Told them it's a direct bolt-on.
they called me later saying they need to find an air gasket first so the air won't leak or something?...
are they legit? as in do i really need an air gasket or jus tell them to bolt it on without buying a gasket?
Old Nov 18, 2005 | 12:17 AM
Ttop34's Avatar
Ttop34
There is a two bolt gasket between the mid pipe and the pipe that goes over the half shaft. You can use the original one if it's in good shape or else get one from the GM dealership, they are just a couple bucks. You can probably just get one from a parts store, I think it's 2 1/2" inside diameter but not entirely sure. Remember to get two of them, one for each side.
Old Nov 18, 2005 | 12:26 AM
GrayC5's Avatar
GrayC5
I haven't installed any B&Bs, but I see no reason why the stock flange gaskets wouldn't work. The stock gaskets (GM #10276792) list at $7.72 each, so you may want to check around for best price. Good luck.
Old Nov 18, 2005 | 12:44 AM
jlcvt's Avatar
jlcvt
Some systems come with new gaskets. Replace if needed, but don't put it back together without them.
Old Nov 18, 2005 | 05:18 AM
604_c5's Avatar
604_c5
yean, i told them to use stock gaskets,
but they said it won't fit...
so they are going to order some for me i guess..
hope it doesnt take too much outta my pcket
thx
Old Nov 18, 2005 | 02:49 PM
Dave68's Avatar
Dave68
My Borla Stingers came with not only new gaskets, but a nice baseball cap as well. You'd think other manufacturers would at least supply you with new gaskets!
To Exhaust question, gaskets. help:)
