Engine removal? After countless internet searches....
Old Nov 18, 2005 | 10:29 AM
RotorHead's Avatar
RotorHead
St. Jude Donor '03-'05-'06-'08, '14
GATORS Chomp OU 4 St. Jude '09
Default Engine removal? After countless internet searches....
......still can't find it.
A friend of mine is removing his LS1 out of his 97. Engine is broke down, engine mounts are disconnected from block, torque tube is diconnected.
What is the next step to obtain the proper clearance between engine and torque tube to remove the engine?
My guess is the torque tube needs to come out
Old Nov 18, 2005 | 11:51 PM
Jay-rod's Avatar
Jay-rod
I have not pulled my motor but I have read on how to do it.If you want to pull it from the bottom you have to remove the engine cradle,If you want to do it from the top i think the rack has to come out.JER
Old Nov 19, 2005 | 12:37 AM
lost's Avatar
lost
The manual says out the bottom but it can be accomplished either way.
Old Nov 19, 2005 | 08:09 AM
78Vette-SA's Avatar
78Vette-SA
There has been other threads on this recently. May want to search or scan back a few days.
Sounds like you are going out through the top. I prefer to drop it but I use a lift so it's easier that way. I just ondo the whole cradle with the engine on it, disconnect everything and the torque tube, lower the engine and slide forward a little, then just raise the car.
If you are going through the top, after unbolting the torque tube, you have to either unbolt the motor mounts from the engine or loosen and lower the cradle with the lower motor mount bolts off. Assuming you have the radiator and fan out of the car and everything disconnected (you can slide the engine forward and remove the wiring harness and grounds from the back of the head and the bellhousing along with the Cam sensor, map sensor, Oil Pressure Sensor and Vacuum line to the brake booster) you still have to slide the engine forward quite a bit as you raise it. The shaft from the torque tube is probably 6-8 or so inches long. You need to clear it of course. The torque tube can flex up and down a bit but don't put too much pressure ont he shaft.
Also, the A/C pump is going to be a hassle either way. You can unbolt it and tie it up out of the way I'll also assume you already removed the starter, exhaust, all wiring, waterpump (more clearance), alternator and bracket, etc. The more you remove the easier it is to get sometimes.
There are tricks to it that you will learn for the next time!
ps: You do not need to remove the torque tube. And don't forget the sensor below the starter. It's a PITA.
Old Nov 19, 2005 | 08:19 AM
TheLaserShop's Avatar
TheLaserShop
You have to drop the front suspension cradle so then motor can move forward. You must loosen the clamp (torque tube spline) inside the inspection hole below the front bellhousing.
Old Nov 19, 2005 | 11:11 AM
RotorHead's Avatar
RotorHead
Thanks to everyone, I will pass this on, and another c5 mechanic is born :
Old Nov 21, 2005 | 12:28 AM
jfrc's Avatar
jfrc
i just pulled my motor Sat
i removed hood, radiator, power steering assembly, disconnected AC comp and left it loose, water pump, starter, clutch line, altenator, etc...
i unbolted tie rods and rack & pinion and moved it forward, to help with the crank pulley clearance
put car in the air and undo one end of the shock
unbolt the aluminum subframe from the main frame
lower the subframe as much as you can, the more the better
undo the bolts from the torque tube to the bell housing
remove bolts to motor mounts
hook up chain, pull forward off the spline, and yank her out
the most time consuming portion is removing all of accessories
once you pass that, it is actually easy to remove the engine from above
now stabbing it back will be another story
Old Nov 21, 2005 | 09:29 AM
78Vette-SA's Avatar
78Vette-SA
Congrats.
Old Nov 21, 2005 | 10:28 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I would love an update on the install procedure. Thanks!
Old Nov 21, 2005 | 11:41 AM
jfrc's Avatar
jfrc
as soon as turkey day passes, i'll start getting stuff to the machine shop
the sooner i get it back the better, before i start to forget stuff
Old Nov 21, 2005 | 01:19 PM
bayarea's Avatar
bayarea
this is exactly what I did yesterday
Old Nov 21, 2005 | 01:43 PM
ragtopws6's Avatar
ragtopws6
This should get you started.
http://forums.corvetteforum.com/show...2&postcount=14
Old Nov 21, 2005 | 08:38 PM
RotorHead's Avatar
RotorHead
Originally Posted by ragtopws6
Old Dec 19, 2005 | 08:59 PM
Cajundude's Avatar
Cajundude
Any updates? Pics? I'm gonna do this in a few weeks. Thanks!
Old Jan 1, 2006 | 03:21 PM
usnskeet21's Avatar
usnskeet21
Any updates/ troubles? I am in the process of removing all accessories taking tons o pics and writing a novel in the process...
Old Jan 1, 2006 | 03:50 PM
edensknight's Avatar
edensknight
Old Jan 4, 2006 | 03:55 PM
madyak's Avatar
madyak
about link does not work....
Old Jan 4, 2006 | 07:31 PM
ScreaminDemon's Avatar
ScreaminDemon
He's right on! I did not have to remove my radiator, and the engine still slipped right out. I removed the torque tube plate to give the tube room to drop a little to negotiate the engine out but you don't have to remove the tube. The hardest part was clearing the intake at the firewall. Playing with a jack under the tranny to find the right angle for the picker is all that is needed. Remove all accessories including starter and bungy them out of the way. It was nice process.
To Engine removal? After countless internet searches....
