Dropping Her Down
Old Nov 21, 2005 | 08:26 AM
Slammed..'s Avatar
Slammed..
Removed front bolts/bushings,9 inch grade 8 bolts in the rear.ZO6 wheels,no rubbing.I could go 19" front and 20" wheels and stay this low,it's all in the tire selection.
A Goodyear F-1 supercar tire. 295/35/18 is 26.1" in dia.(top to bottom)
A Pirelli PZero nero tire......... 285/25/20 is 25.6" in dia.
Actually a hair shorter.If you like that look,(more rim- less tire),i do...I will get this set up after power mods.
25" front..
26" rear...
Old Nov 25, 2005 | 06:27 AM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Default xxsvtcorbrakidxx...here are your pics
http://i3.photobucket.com/albums/y92...mbervette2.jpg
http://i3.photobucket.com/albums/y92...mbervette1.jpg
Sorry but I get dozens of emails a day and when you just sent the pictures with no commentary I wasn't sure who you were
PS: Nice ride
Old Nov 28, 2005 | 09:16 PM
C52000C5's Avatar
C52000C5
Old Nov 29, 2005 | 06:10 PM
C52000C5's Avatar
C52000C5
Old Nov 29, 2005 | 06:19 PM
DPG's Avatar
DPG
St. Jude Donor '06
here is a pic of mine lowered on stock bolts
http://www.villagephotos.com/viewpub...4298&selected=
and here is a pic of her with no bushings up front excpet for a thin piece of rubber and the rear with 7 or 8 inch bolts, but i have some washers the raise the rear to the right rake
http://www.villagephotos.com/viewpub...5463&selected=
http://www.villagephotos.com/viewpub...5464&selected=
oh and invest in the frame savers and the rollers
Old Nov 29, 2005 | 10:11 PM
turboc5's Avatar
turboc5
Awsome, I just figured out how to post pix. Anyhow it has cut front bushings(but not completly removed) and a rear lowering kit. 18x11 and 18x12 ccw's with 305's and 335's
Old Nov 29, 2005 | 11:43 PM
edensknight's Avatar
edensknight
Coil over springs is the way to go!
Old Dec 2, 2005 | 10:26 PM
C52000C5's Avatar
C52000C5
Old Dec 2, 2005 | 10:37 PM
jjcslynn's Avatar
jjcslynn
If I lower using the stock bolts, do I need to get another alignment?
Old Dec 2, 2005 | 11:45 PM
Dark-Knight's Avatar
Dark-Knight
Down about 3/4" on stock bolts...
Old Dec 2, 2005 | 11:54 PM
Rhode Warrior's Avatar
Rhode Warrior
Originally Posted by BBates
Just did mine about a month ago. Lowered on stock bolts with stock C5 size tires. I wouldn't want to go much lower. I can barely get it in the driveway now. But, it does look much better.
I did the same. It looks great and is OK to drive, but I would definitely not go any lower.
Old Dec 3, 2005 | 08:13 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Yes.
  #33
0EG@EnglandGreen
Supporting Tuner
Originally Posted by MawneeC5
Haha, you are a lunatic !
Old Dec 5, 2005 | 10:49 AM
  #34
C52000C5's Avatar
C52000C5
Old Dec 5, 2005 | 12:15 PM
  #35
01QSZ06's Avatar
01QSZ06
Here's some pics of mine! All on stock hardware and I didn't cut the back bushings all the way!! Night/Day difference.
http://pg.photos.yahoo.com/ph/j_burb...bum?.dir=/2a35
