Emmissions question....
Old Nov 22, 2005 | 12:07 PM
Jstyle's Avatar
Jstyle
Default Emmissions question....
I know if I lean the A\F really REALLY lean I can pass emmissions. Now I know this is dangerous and not advisable however what is the best way to do this to make it just up to a sniffer facility?
Old Nov 22, 2005 | 12:42 PM
davette's Avatar
davette
It depends. The leaner a car runs, the higher is NOx emissions.
Not sure about the state of VA, but in California, we have a maximum about of NOx level a car can put out. If you go over, you fail.
Secondly, to lean out your car that much would require changing your software program. These cars are so smart, it may not even allow you to lean it out to an unsafe level.
Good Luck.
Old Nov 22, 2005 | 01:10 PM
Jstyle's Avatar
Jstyle
Any one know of a way to pass emmisions on a GX3?
Old Nov 22, 2005 | 10:03 PM
novaZkid's Avatar
novaZkid
Cruising
J style,
don't know if you had your emissions done recently, but you should be able to pass in VA as long as you don't have more than 2 "engine monitors" not ready if you have a 96-2000, or 2001 and up allow only 1 not ready. Basically the test is only done w/ the OBD. if that's all good, you'll pass. This is pretty recent; i think since may or so this year.
this is assuming you're not running so rich as to have constant black smoke going out the tailpipe!
Old Nov 23, 2005 | 12:02 PM
Jstyle's Avatar
Jstyle
So its not a sniffer any more? Because in the past its always been a sniffer test.
Old Nov 23, 2005 | 02:29 PM
DPG's Avatar
DPG
St. Jude Donor '06
i know that here in the chicagoland area that in cars 97 and up with OBDII systems, they only check to see if you have any engine codes with a scanner. No sniffers or anythign like that.
Old Nov 24, 2005 | 11:43 AM
Jstyle's Avatar
Jstyle
In North VA they all use sniffer test.
To Emmissions question....
