good cam?
Old Nov 25, 2005 | 12:02 AM
fotoboy's Avatar
fotoboy
Default good cam?
Would like to RR and Drag what do you think about this cam?
current setup is PP ls6 head and full bolt ons 98 346 ci. c5 m6 3.42 gear maybe going 3.90
SI5 231 237 .589 .595 112 from speed inc.
Does anybody have any dyno sheets on this cam?
Old Nov 25, 2005 | 12:06 AM
Synergy Motorsports's Avatar
0Synergy Motorsports
Former Vendor
Your gearing will be the deciding factor on what cam you put in there. Pick the gear first, then grind your cam. That cam would be better for the 3.90 gears. Drop it down to a 112 lsa if you stick with the 3.42 gears.
Rick
Old Nov 25, 2005 | 12:10 AM
fotoboy's Avatar
fotoboy
already have the cam, but that can change, why would you stay with 112 over 112+2?
Old Nov 25, 2005 | 12:14 AM
Former Vendor
You only said the cam was a 114. If its a 114 +2 then you get alittle more cylinder pressure, but less up top. The reason you want the tighter LSA with 3.42's is because you need more TQ to push through that gear. If you have the 3.90, then you need a longer power band. Hope this helps.
Rick
Old Nov 25, 2005 | 12:25 AM
fotoboy's Avatar
fotoboy
sorry its a 112 not a 114 your right its hard to keep the car from bogging out of the hole of bfgs and a 5200rpm launch so may be 112 -2? I guess I dont undersatand the diff in this # and what it does.
**** wrong specs here are the new ones:
Old Nov 25, 2005 | 12:45 AM
black98c5's Avatar
black98c5
im looking for a place to do h/c, what does speed inc charge for the pp ls6 heads and a cam pkg if you dont mind me asking.
Old Nov 25, 2005 | 12:53 AM
fotoboy's Avatar
fotoboy
Doing HC swap my self over the winter so I cant help you sorry fellow 98 blk c5
Old Nov 25, 2005 | 12:58 AM
black98c5's Avatar
black98c5
thanks anyway. let us know how that goes and try to post some numbers
Old Nov 25, 2005 | 01:18 AM
fotoboy's Avatar
fotoboy
seen 430 rwhp with my setup I expect the same, have seen dyno sheets to 400 with cam only full bolt ons and 381 tq
Old Nov 25, 2005 | 10:55 AM
Former Vendor
I would stay away from anything larger than 230ish duration. It becomes un needed. I havent seen many people make any difference in numbers with the big internet cams. They actually loose TQ.
If you get a 112 lsa cam, just get one without advance in it. 112+0
Rick
Old Nov 25, 2005 | 11:00 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Rick,
I'm currently running 234/240 598/608 on a 114+0LSA and with my 3.90 gears and SS3600 stall it screams. I love it. I'm surprised that you think anything above a 230 is "too big"
Please explain
Stephen
Old Nov 25, 2005 | 11:11 AM
Former Vendor
Originally Posted by EnglandGreen
Rick,
Please explain
Stephen
If you look at your setup versus his setup, you will find the comparison not even close.
You dont have to worry about any power or drivability issues below your stall speed. Then on top you have gears. So for you, this comparison would not work. Take that same cam and tell me how fun it would be in a stick car with stock gears. I think you would change the cam real fast once you find you cant get out of the RPM band that quick..
Rick
Old Nov 25, 2005 | 12:36 PM
fotoboy's Avatar
fotoboy
Rick
I had thetiming gear machined so I could advance/ retard it, do you still think this is ok for my set up or would you recomend another?
The standard lsa is 112 on the cam
Old Nov 26, 2005 | 04:09 PM
fotoboy's Avatar
fotoboy
ttt
Old Nov 26, 2005 | 08:05 PM
WKMCD's Avatar
WKMCD
Rick
Thanks Rick for confirmation.
I run a 230/236 112 XE-R .598/.610 cam with an M6, A&A Stage 2 heads (11.2:1), FAST LSX and LS2 TB and all the bolt ons. I runs great and I can even drive it in rush hour DC traffic. That's bumper to bumper at 4-5 MPH. I also have a speed density tune by PHIL97SVT. I don't think I'd run a cam this large without the SD tuning for the type of driving that I can get caught in. No dyno numbers but the car screams and idles at 825 RPM. I also don't have to spin it unreasonable high to make great power. Rev limited is set to 6600RPM.
Old Nov 26, 2005 | 09:37 PM
fotoboy's Avatar
fotoboy
ttt
Old Nov 28, 2005 | 11:05 AM
fotoboy's Avatar
fotoboy
ttt
would like so more info if any body has any.
To good cam?
