Using Rope when changing valve springs
Old Nov 25, 2005 | 07:17 PM
unstressed's Avatar
unstressed
Default Using Rope when changing valve springs
Does the old rope trick still work on the LS1?
Pull the spark plug, put some rope in the cylinder, turn the motor over by hand.
When the piston gets near TDC, the rope squishes and keeps the valves from falling.
Anyone still do this?
The air fitting is OK, but this way used to be fool proof.
Old Nov 25, 2005 | 08:19 PM
CYA-Vett's Avatar
CYA-Vett
Rope will work, but the air fitting is fullproof too, with 80 psi in a cylinder, there is not way your valve drops.
Old Nov 25, 2005 | 09:31 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
Old Nov 26, 2005 | 08:55 AM
vettenuts's Avatar
vettenuts
I used the TDC method, no rope. Just make sure the piston is at the top and the valve will only drop 1/4" and you can change the springs. I don't like the compressor as I had a failure once and dropped a valve. I always used the rope until this last time on the Vette and used the TDC method. I have access to a boroscope though, so ensuring the piston is at the top is easy.
Old Nov 26, 2005 | 08:58 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
never tried the TDC method, seems it would be quicer than install/removing the air fitting into each cylinder
Old Nov 26, 2005 | 09:50 AM
JC5's Avatar
JC5
The rope method worked great for me!
Old Nov 26, 2005 | 09:54 AM
CYA-Vett's Avatar
CYA-Vett
How did it fail??? Power went out? Hose sprung a leak? Forgot to turn the compressor on? I Simply can't see how it could fail, but maybe I'm missing something???
Old Nov 27, 2005 | 01:49 PM
vettenuts's Avatar
vettenuts
I had to run back to my house to get a tool (I was in a neighbor's garage), compressor stopped and valve dropped. Fortunately (this was my daughter's Nissan) I had gotten to the point with that particular car that pulling the head for me was like a NASCAR team changing tires, don't ask me why
Old Nov 27, 2005 | 07:03 PM
gonbad's Avatar
gonbad
It can fail if while screwing the spring compressor down the valve doesn't pop out of the locks. It opens enough to release the pressure just about the time the locks popout. It happened to me twice when doing my cam swap. Both times I was lucky enough that cylinder was high enough to keep the valve from completely dropping out.
To Using Rope when changing valve springs
