This may sound like a real stupid questions, but is there anyway to tell if a Z06 wheel and tire has a tire sensor on it with mounting the wheel on the car or taking the tire off? Thanks
I would simply find a vette that has wheels that you know has sensors in it, and check for similarities. Maybe somebody could post up a close up.???? Either that or bolt one up to your vette and try to run the sensor recalibration. Probably wouldnt even have to be on the rotors..just real close assuming you have the TPS active on your vette.
Just got set of 04 polished Z06 wheels and tires for 01 coupe and not sure if original owner took out sensors..... I wanted to save the time and expense of having my sensors removed and install on new wheels.
I know I could just mount the new wheels, but I get home late and don't have jack at hand. Thanks again
ET hit the nail on the head (as ever), look for the metal nut. If you're not sure, try to program it. However, you don't need to mount the wheel, it just needs to be near the car. It'll take you less than a minute to check one and the others are probably the same, no?
Z06 wheels do not come with them so I would say no. Unless they were added to them as I did. The pictures above should help you identify without taking anything apart.
