10PCM P1431 H
10PCM P1626 H
28 TCS C1255 H
40 BCM No Comm
60 IPC U1176 H C
60 IPC U1160 H C
99 HVAC No Comm
A1-RDCM U 1064 H
A0-LCDM U 1064 H
B0-RFA U 1064 H
Anyone know what these mean? Ive been having Battery problems and what seems to be electrical problems.
Battery problems will definitely throw codes. All the one's ending in "H" are history. only the "C"'s are current. Here's a link to all the DTC's for 1997-2000 and alot more. Hope this helps. http://www.corvetteactioncenter.com/....php?qstId=242
clear them out, then see what you have, 1064 is low voltage, often seen, ck Bill Curlee's sticky at the top of the page, you may have water in the bcm area, where the pass. feet rest
I did change the battery and it fixed the problem for about 10 seconds, then the lights started flickering again and they finally dimmed out....a ticking was heard by the passenger feet...by the fuse box. The car wont even try to turn over anymore and everything but the headlights are dead....
40 BCM No Comm
60 IPC U1176 H C
60 IPC U1160 H C
99 HVAC No Comm
The BCM "no comm" is your major malfunction, pull the passenger side floor mat up and remove the footwell cover to see the BCM, make sure the floor and the compartment are dry, if they are just get a new BCM and be done but if either is wet then you'll have to figure out where the water is coming from before you replace the BCM.
