Head/header installation
Old Dec 5, 2005 | 08:17 AM
Classical Glass's Avatar
Classical Glass
Default Head/header installation
I'm going to install some long tube headers in my 02 this winter also new heads.My question is by installing the heads would that make the installation of the long tube headers easer since the heads will be removed from the engine? Also i just want to bump up the hp a couple notches not full racing just some street fun, what do you recommend for a good ported head and valve set up? Thanks in advance.....
Old Dec 5, 2005 | 10:23 AM
DPG's Avatar
DPG
St. Jude Donor '06
i would think so. with most of the header installs the the coil paks and waht not are in the way. Just remember to put the headers in before you put the heads in. Correct if im wrong.
Old Dec 5, 2005 | 11:26 AM
WKMCD's Avatar
WKMCD
Definitely easier. Anything to get you more wiggle room will help. Drop the headers in but don't connect them in the rear. You will still need to move them around to get them up to the exhaust ports.
Old Dec 5, 2005 | 04:35 PM
Ken G's Avatar
Ken G
I just did this a month or so ago and it was VERY easy to put my Supermaxx's in with the heads off. They just slid right down from the top on both sides.
Old Dec 5, 2005 | 04:40 PM
Silver98's Avatar
Silver98
I'm researching the same thing right now. I've learned a lot from :CHEVY LS1/LS6 Performance by Christopher Endres. It covers a bunch of numbers and recommendations about the LS6 vs LS1 headers and porting. Give it a go, great reference book.
Old Dec 5, 2005 | 06:29 PM
vettenuts's Avatar
vettenuts
Stay with small ports. AFR 205's come to mind as do the new ones from Precision Porting that Bob recently posted photo's of here on the forum. The ET Performance heads look real nice, but apparently they are not drop in and require changes to the spark plug wires and the alternator bracket. Jury is out on the Darts and the Edelbrock heads as well as Trick Flow. The AFR's are written up in the new issue of Corvette Enthusiast magazine (January 2006) where Vinci High Performance put them on a stock C5 and picked up about 40 HP at the wheels
To Head/header installation
