common problems on 99's
Oil pressure sensor
Fobs
Left differential oil seal
Right fuel tank level sensor
Door lock relays
Ground problems
Cracked flange welds on exhaust system
Got rid of the run flat tires and got a spare and jack
Had a four-wheel alignment done.
Would anyone like to comment on any other problems that might be common to 99’s. I really like these cars but I don’t know if I can afford to keep one. I hate to settle for a Honda just because they don’t break.
Other issues witht the car, gas gage drops to empty, ususally happens when I but in cheap highway gas. Driver side window doesn't always come down. Both issues do not happen very often.
Nothing to worry about, overall a great car.
Overall, I am very happy with my C5. Now if you want to hear a horror story let me tell you about my '02 TrailBlazer.......
Ike
Oil pressure sensor
Fobs
Door lock relays
Ground problems
Ike
Awesome dependability despite the little quirks
Oil pressure sensor Nope
Fobs Nope
Left differential oil seal It weeps, but not enough to drop any fluid on the garage floor. Only time I ever smell any diff. fluid is after a day racing
Right fuel tank level sensor Nope
Door lock relays Nope
Ground problems Not really, but I did have a problem caused by a wire in the driver's door bundle that had the insulation pull back and erratically ground itself to the chassis. Mr. Murphy at work.
Cracked flange welds on exhaust system Yep
Got rid of the run flat tires and got a spare and jack While this isn't a quality/reliability problem, I run non-RFs and pack a 12v compressor and a plug kit. I've used it once in anger and it worked like a charm!
Had a four-wheel alignment done. I don't understand why you lump this in as a "problem" on your car. Every car I've owned has had an alignment done when I bought it, including Hondas.
Things just break on mechanical items. If you perceive the Hondas to be better, be my guest; I've owned them in the past and wouldn't mind owning one in the future if it meets my needs. But to expect perfection in a car that's 6-7 years old (regardless of miles) is a quest towards disappointment.
HTH, and have a good one,
Mike
Oil pressure sensor
Fobs
Door lock relays
Ground problems
When I first bought mine 3 yrs ago I drove it for a week and the change oil light came on. I took it to the dealer after I had spent 2 days shining it up inside and out. When I got it back later, they handed me a bill for $90 and there were greasy handprints on the door, the hood, the steering wheel, and the stick shift. I got grease all aver my hands and my white dockers
I cancelled my service contract that day and have been doing all my own repairs and upgrades since, except for my gears and rear end, thanks ECS I have learned 2 things from this...
1: The car might as well be a John Deere lawn tractor as far as most service departments are concerned, except it costs 50% more to service this model tractor and they break stuff in the process of fixing other stuff.
2: As customers, all we are is a paycheck to the dealers. Get it in, fix it fast, get it out so we can do the next car.
There may be good service departments out there, but I havn't found them. The best thing I did for my car was to invest in a lift, tools, and a set of service manuals and learn how to take care of things myself. Example, when I bought my Vette the guy selling me the service contract told me what If I get on it and blow a head gasket, it would cost $1500 fix. Hmmm, now it costs me the price of the gaskets, the bolt kit, and a day or 2 work that is being done with TLC, and not an eye on the clock and the bank account.
This may not be the best solution for everybody, but it seems to have been for me. I got to use all that experience turning wrenches I got from back in high school when I had my '55 chevy 327/4speed, 4:10's...
I agree somewhat. I think they should have made a Z06 track model and released it as an almost non-daily driveable car and left for the hardcore enthusiast. A/C/, carpeting, sound deadening, reclining seats, traction control, stereo, hydraulic line restrictions, and some other things should be thrown out the window.
Oil pressure sensor
Fobs
Door lock relays
Ground problems
Items I consider Non-Routine repairs
Repaired Cracked flange welds on exhaust system
Replaced one and had both Fobs Reprogramed
Replaced one of the tire sensors
Replaced left cover "o" ring seal and left shaft seal
Replaced HVAC door servo
Items I consider routine maintanence
Replace tires (Michelien RF Pilots)
4Wheel alignment
All fluids changed
4Wheel brake job
My bigest complaints are:
That the tire sensor's batterys were not designed to be changed. I know some people have done it but why couldn't the factory have demanded that they be designed to be easy to replace.
Knowing that many of us do not use our cars as daily drivers why could they not have designed the electrical system to be put in a dormant mode so they wouldn't kill the battery in just a couple of weeks. I understand the C-6 is even worse about this. It will actually roll the windows down when the voltage goes below a certain level. Great for any car sitting say out at the Airport!
