Engine oil removal
Besides, how are you going to change the filter?
To paraphrase Nike "Just drain it!"
HTH, and have a good one,
Mike
Mike[/QUOTE
TRUE. But supose he's going to put his car up on a set of rhino ramps to remove his oil filter. Now the "rake" is front to back. Would he now be in a better position to drain his oil from up top ??
BTW, welcome to the Forum!
Using Rhino ramps, the proper technique would be to back the car up onto the ramps, then drain the engine. Unless the car is really slammed (which could cause the nose to drag) you should have enough clearance for a drain pan underneath.
Mike
Mike[/QUOTE
anyway, once, i tried the rhino ramp thing w/o jacking the rear of the car. after i drained the oil (apporx 20 minutes), i raised the rear slightly higher than the front, and got an additional 1/2 to 3/4 qt to drain. after allowing for a complete drain (again, approx 20 mins), and a new upf44 filter, both my (late) 2000 coupe and my (present) 04z06 both, take or took, 6.75 qts. i think by draining in a level position, one would get approx 6.5 qts out - by raising the rear slightly, you'll probably get an extra .25 qt. as far as those various vacuum operated oil change thru the dipstick tube extraction systems for removing the oil from the top, well THAT SUCKS!
i don't know about you, but i'm pretty **** - i want to get as much of the old oil out during an oil change as i can.
1. jack the rear up just slightly more then the front, that gets a bit but not much more.
2. run a full quart of oil though the motor. Pour a new bottle into the oil fill with the drain plug out. WHen you see clear oil come out the bottom you good to go. Takes about 1/3 to 3/4 qt to get the remaining slug out.
Let it drain for a good 30 min. Then put in the drain plug, put 3/4 qt or about that into the oil filter, put on oil filter, fill with oil.
So are you waisting an extra quart of oil?? I say no, it helps clean out the old oil.
cheers
If you have the agility and knees to get under the car once in a while, it's not a bad idea to do a little inspecting. No one will care about your car like you will.
cheers
Go for it. I like the way you think.
