Sway Bars
Old Dec 6, 2005 | 12:30 AM
mike94z28's Avatar
mike94z28
Default Sway Bars
Should i go with the T1 swaybars or should i go with the Z06 bars. I have the Z51 sus. now and i am just thinking that the Z06 bars wont be much of a difference. any help either way would be greatly appreciated thanks.
Old Dec 6, 2005 | 01:24 AM
ericdwong's Avatar
ericdwong
What kind of application? Track only? Street only? Little of both?
Old Dec 6, 2005 | 01:09 PM
MattB's Avatar
MattB
Also what year Z51? '00 - '04 the rear Z51 and Z06 were the same. Also, search a little here; someone was saying that the stiffness was not liner in relation to the diameter. Meaning a couple of mm more in diameter is a large difference in stiffness.
I just bought some Hotchkiss , but I'm still in the process of installing (doing some other things as well ) so I can't say how the perform. But, just by looks they are huge compared to the base bars.
Check out this link for info:
http://www.jakelatham.com/c5/misc/faq.shtml#2-1
Old Dec 6, 2005 | 01:47 PM
ANTIVINUM's Avatar
ANTIVINUM
I have the T1 bars and they are great. The end links suck but other than that I would go with T1. The Z06 is just not going to be a big difference and you stand a chance of being disappointed and out some money. You can usually find a set of used T1 bars here on the forum or on Ebay.
Old Dec 6, 2005 | 03:08 PM
mike94z28's Avatar
mike94z28
Sorry about that my car is a 00 and i plan on doing alittle of both street and track
Old Dec 6, 2005 | 08:02 PM
SmashF15C's Avatar
SmashF15C
Not to hijack your thread Mike, but I also have an 00 and am probably never gonna track; but driving at 130-160 MPH daily on the Autobahn - I was tossing around Hotchkiss vs Z06 and still cannot decide. I have F45 and love the shock adjustment.
Would love to hear any comment.
Smash
Old Dec 6, 2005 | 08:47 PM
Dark-Knight's Avatar
Dark-Knight
I got the Z06 sways for the street, great mod! Noticable improvement over stock, very flat in the turns.
Old Dec 7, 2005 | 06:28 PM
mountainbiker2's Avatar
mountainbiker2
How is the balance of your car right now. Your Z-51 rear is the same as a Z06. If you put on a Z06 front you will pick up understeer. If that's what you need then great. T-1 does not work for autocross. Hotchkis is stiffer then what you have, but then again you might get more understeer then you have right now.
For me I went with Z06 front and Hotchkis rear.
Goodluck in your choice.
Steve
Old Dec 7, 2005 | 07:02 PM
AU N EGL's Avatar
AU N EGL
Blue is T1 (38.4mm) and black is 03 Z51 ( 28.4 mm)
for the street rocks would be softer and more compliant then the T1 bars.
The full 04 ZO6 suppension may work better. rember suppension work a s a full system not piece meal.
Old Jan 12, 2006 | 07:55 PM
AMERICANMUSL's Avatar
AMERICANMUSL
Can anyone tell me if the Hotchkis endlinks will work with the T1 Bars?
To Sway Bars
