Not sure, but I'm under the impression that when the engine is running, the battery is under a 'float charge', so the voltage regulating alternator should be handling all electrical loads. If the battery has a bad cell, it MAY be causing the alternator to put out a ton of power, but that should manifest itself with higher than normal voltage on your DIC / IP, and a slight drop (1 - 1.5 vDC) would be noticable, but not the root cause.
When putting on the brakes, the engine RPM's drop, do you notice a drop in output voltage anytime the RPM's drop?
You should measure the voltage at the output terminal of the alternator and at the battery terminals to see if there is a voltage drop between the two. You will normaly see the voltage drop a little when different loads are applied to the circuit.
The expert on alternators is Evil Twin! I know from many past post that if you get a rebuilt alternator from a run of the mill auto parts store, you may not get the correct one for your car! You may end up worse off than you were! NEVER give up your OEM alternator!! If there is a problem with it, I recommend having it rebuilt rather than replacing it.
I will do a test on my 02 Z06 tonight and see what i get for a drop.
If you measure the battery with the car off it should measure 12v. If you have a dead cell it will be less. I think with the car running it should measure something like 14v. Have someone step on the brake while you measure the battery
This is normal, drive another car at night and you'll notice the same thing, sometimes at night when I'm driving my truck my headlights will dim when I take my foot off the gas.
The voltage regulator can only regulate the voltage so much, it will never be able to hold it exactly at a constant voltage.
I don't have anything to really test the battery or the alt. output with. I just look at the volt meter on the control panel thing (I'm not sure of the correct term of it. New-be here.)
I only really see a drop in the volts is when I either put on the brakes or kick the A/C on. When I turn on the AC, it drops over 2 volts then it jumps right back up to 14.2 volts.
The RPMs don't drop or anything like that when I do both the AC and the brakes. The volts just drop and they come right back up.
Well your alternator's working fine then, after all you just said.
If you go to AutoZone or Advanced Auto parts, they have a cart they will hook up to your battery (while in the car) and place a load on it to determine if the battery or even a cell is bad. and its free.
