Front Fender Removal?
Old Dec 19, 2005 | 01:58 PM
marco383's Avatar
marco383
Default Front Fender Removal?
This may be one of the lamer posts ever seen on this forum, but are there any tricks/pitfalls involved in removing the driver's side front fender in a '98? I need to gain access to the Accusump that I had mounted in the fenderwell.
Old Dec 19, 2005 | 02:17 PM
vette747's Avatar
vette747
Front fender removal
1. Raise the vehicle and suitably support.
2. Remove the tire and wheel.
3. Remove the wheelhouse filler panel.
4. Remove the rear inner panel.
5. Remove the bolts attaching the fender opening to the wheelhouse
6. Remove the bolt under the fender to the rocker panel.
7. Remove the bolt attaching the fender rear center flange to the hinge pillar.
8. Remove the fascia front close-out panel.
9. Remove the bolts from the fascia to the skid bar.
10. Remove the headlamp housing.
11. Lower the vehicle.
12. Remove the bolts attaching the fender to the wheelhouse upper front flange.
13. Remove the nuts attaching the fascia to the fender reinforcement studs.
14. Remove the bolts attaching the fender to the upper hinge pillar fender bracket.
15. Remove the screws attaching the fender ot the upper wheelhouse flange.
16. Remove the fender.
Old Dec 19, 2005 | 03:34 PM
marco383's Avatar
marco383
Thanks for the quick reply!
Old Dec 19, 2005 | 03:43 PM
AU N EGL's Avatar
AU N EGL
The nuts and screws or torxes screws by the head light and attaching to the front fender are a bear. cant always see what your doing.
Old Dec 19, 2005 | 06:44 PM
Jake T's Avatar
Jake T
Something tells me you've done this a few times!
To Front Fender Removal?
