Pushrod Measurement Procedure
1. Remove intake and exhaust springs on new heads, replace with checker springs
2. Install Morel hydraulic roller lifters into checking locations
3. Install head on car using old gasket and tighten enough to remove clearances (around 15 lb-ft) Note I will be using stock GM gasket on the new heads.
4. Make sure intake is on base circle of cam, install checking push rod
5. Mark up top of valve with Sharpie
6. Install Crane adjustable rocker and finger tight to zero lash point
7. Rotate motor and check swipe, once correct then push rod length is established
Repeat the process on the exhaust valve.
At this point, do I need to alter the measured length?
stock push rod in place at zero lash(finger tight), scribe the point where the rod comes thru the head
then torque rocker arm to 22-24 ftlbs and scribe again.
measure distance between the two marks. Comp OEM lifters 850-16 need 0.040" preload. If your distance is larger than 0.040" then you need shorter push rods. If your distance is smaller than 0.040" then you need longer push rods.
I have the distinct advantage since my motor is installed, and running. Now I can order the correct hardened push rods.
When I adjusted mine, I used the Zero lash method and used a magnetic base mounted dial indiactor to measure the lifter preload distance...Then you cancheck the swipe mark to see if you need a longer pushrod.
