Oil stop leak?
Old Dec 21, 2005 | 11:32 AM
ztron's Avatar
ztron
Default Oil stop leak?
Whats everyone opinion of the oil additive stop leak,, any brand.. have you used any?, whats the downside?, etc etc..... I see that Redex Stop Oil Leak can be used with reg or syn...
Old Dec 21, 2005 | 12:22 PM
Ttop34's Avatar
Ttop34
I dump the stuff into my Jeep because I hate it and it has a big leak in the rear main seal. I'd never use anything in the vette that is made to gum up a hole. It has been stated on here many times that the LS1 has tight tollerances and needs good oil flow.
Oh a side note, going to the Cottonbowl? I'll be there!
Actually have two tickets for sale, if you need them let me know.
Old Dec 21, 2005 | 01:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My recommendation would be to find the leak and fix the problem. Unless it is something like a block that has a slight bit of porisoty and it is out of warranty, i wouldnt use it.
My 2 cents.
Bill C
Old Dec 21, 2005 | 01:51 PM
byte_me's Avatar
byte_me
My 2 cents.
Bill C
I would not do it in a vette...find the problem and fix it if possible...that stuff gets NASTY quick and on a high perf engine...I would not want that molasses in there one bit!
Old Dec 21, 2005 | 03:17 PM
ztron's Avatar
ztron
ok, guys you make for a very strong case,,,, guess I'll have to deal with it a little while longer,,, thanks
Old Dec 21, 2005 | 08:28 PM
turboc5's Avatar
turboc5
Some of the stop leak is actualy very chemicaly simular to brake fluid. what it does is it softens and swells the rubber seals, stopping the leaks. How ever it stops the leaks but the seals get so soft and gummy that they will deterarate even faster. So instead of having one leak now, in 6 months you will have 10 more.
Old Dec 22, 2005 | 06:26 AM
vettenuts's Avatar
vettenuts
Where is the oil coming from, do you know?
Old Dec 22, 2005 | 08:56 AM
ztron's Avatar
ztron
I took it to a oil change place,, a very young guy looked at it and said that it looks like the Oil pan is leaking and so is the rear main seal... Thats all I know at this point.. After it has been driven for a while when I stop I smell burnig oil... My oil sending unit is out also,,,, gauge reads 80+psi... any help would be appreciated....
Old Dec 22, 2005 | 01:15 PM
vettenuts's Avatar
vettenuts
Oil pressure sending unit is right on the top of the motor, in the back. That may be the source of the leak and the oil is simply running down the bellhousing. That certainly sounds like a good place to start.
Old Dec 22, 2005 | 01:38 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is a picture of the engine with the intake removed. The oil pressure sensor is in the rear on the right hand (drivers side) of the engine.
It has an ORANGE wire and a BLACK/White stripe wire. Use a mirror and see if you can look back behind the manifold and see if that is the source of the leak. You are still going to have to replace the sensor but, it will be staisfying to know that you are solving two problems with one repair.
Please keep us up to date on the results of your repairs.
BC
To Oil stop leak?
