Input On Next Mods
Old Dec 27, 2005 | 11:10 AM
BIGMAC's Avatar
BIGMAC
Default Input On Next Mods
Please see signature for current mods and best 1/4 times. What additional mods could squeeze a bit more out of a internally stock '98 LS1? I don't want to go to heads/cam, forced induction, or nitrous (yet!). I want to stay with the 3.42 gears and 2600 stall. I want to keep the stock cats. Some ideas:
LS6 or FAST intake
"High Lift" rocker arms
Larger throttle body
Thanks in advance for Forum inputs.
Old Dec 27, 2005 | 12:49 PM
ScottN's Avatar
ScottN
St. Jude Donor '05
The LS6 intake would be a good choice. From what I've read, the benefits of the LSX Fast Intake are NOT realized unless you have more cubes or a head/cam setup. The LS6 intake should give you a lbump in power.
Not sure if you have one already but what about a Transgo shift kit. I hear they are fun and would match up well with your converter/gears setup.
Old Dec 27, 2005 | 12:53 PM
mdhmi's Avatar
mdhmi
An LS6 intake might help you pick up 1/10 or 1 MPH in the 1/4, but, that's about it with your combo.
Personally, I'd leave it alone until you're ready to go fast.
Mark
Old Dec 27, 2005 | 01:00 PM
IFLUBYU's Avatar
IFLUBYU
Get an S2 ported throttlebody, it's worth it just for the better throttle response alone.
The LS6 intake is a very easy DIY, and fairly inexpensive. Not a huge gain, but enough that it counts, and opens up for other things. If you are talking about a Fast 78mm, that's cool, but you might as well stay with the LS6. If you are talking about a 90mm setup, that would be over the top.
Doing the rockers is almost as good as a cam, but if you are anywhere considering a cam, I would go that route instead. Either way this is a little more expensive, but a real upgrade that can be felt. If you do the rockers at a higher ratio, you need to do the springs also. I would go with a set of hardened pushrods while you are in there. I suggest: Crane 1.8s (1.82)
Comp 918 valve springs
Comp hardened pushrods
If you have to do something (and I know the feeling) just do the LS6 intake for now, and think about a head/cam down the road.
Not an expert, just my $.02... Good Luck!
Old Dec 27, 2005 | 01:49 PM
IamN2Speed's Avatar
IamN2Speed
Personally, I think you should step up the gears a bit. Nothing will give you more SOTP bump, and you since you have drag radials, you can keep 1st planted. Move up to 3.73s.
To Input On Next Mods
