Help With a Code
Old Dec 29, 2005 | 08:25 PM
dyal980's Avatar
dyal980
Default Help With a Code
I have 98 coupe, just found out how to go thru the codes and i have one PCM code of P1870 H C showing and i can't find it in any list, please help.
Well I Just Cleared all codes and went for a drive and now what it shows is : P0650 C
Thanks For the Help
Old Dec 29, 2005 | 09:19 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Hey Conway
The first code has to do with the Trans. The computer still thinks you have a 3:15 rear. The speed the car thinks it should be going and the speed the car is really going is not the same so it sends a code. the 2nd code I have no idea about I read it and it has somthing to do with the Service engine soon light. I will scan it a bring it in the morning.
Will you be up around 7am
PS are you keeping the car?
Old Dec 29, 2005 | 09:56 PM
dyal980's Avatar
dyal980
Yes, I will Be up, Yes , I think I will Keep it, I have a glass top and x-pipe coming for it.
Old Dec 29, 2005 | 11:12 PM
navy99vert's Avatar
navy99vert
Old Dec 29, 2005 | 11:13 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Here is some more info from The service manual
File Type: doc
File Type: doc
Old Dec 29, 2005 | 11:46 PM
dyal980's Avatar
dyal980
Thanks NOT-MEE, i think this will help.
Old Jan 2, 2006 | 10:31 PM
dyal980's Avatar
dyal980
It was a blown Check engine light.
To Help With a Code
