I have a H/C combo on my 03 Coupe. It is not a daily driver and sometimes it will sit for 2 weeks without having the engine started.
I broke a valve spring and bent a valve a few weeks ago.
Since the engine was not started and the springs did not get any lubricant during that time, is it safe to say that the lack of lube caused or contributed to the busted spring?
Hopefully the new springs (and valve) that I just installed will last a lot longer!
I suppose there are are lots of Vette owners in the snowbelt who don't start thier cars for months at a time and don't have any problems.
Valve spring failure is typically caused by fatigue. Fatigue is a function of material properties, number of cycles and stress state. So, it depends on how your springs are setup (installed height), your open height (how much you are compressing) and how much you drive the car. In addition, running the springs hard when cold can also contribute to their demise.
My 68 dropped a valve because of spring binding at high revs (bad choice of springs) and bazookad a cylinder wall and head. However, in your case, I'll bet the spring was flawed at the factory. What did Andy say?
I think they were REV springs which I've heard had some problems. My cam isn't big (220/220). Mike "unstressed" and I fixed it yesterday. He did most of the work .
If it's fatigue, Interesting that only one spring failed when they all saw the same number of cycles. More likely there was some kind of flaw. I suppose one could say it fatigued at the flaw..............
There have been some problems with the REV springs in the past, and I think it was attributed to material issues. A surface flaw will obviously accelerate the failure.
Very hard metals, that are susceptible to cracking, have a glass transition temperature, i.e., a lower temperature that will promote cracking. The farther from the glass transition temperature you are the better, so with aftermarket springs which tend to be much harder than stock I always make sure my oil is at 180 before running them too hard.
Spring theory, hmm, didn't I take that in Physics?
A well known way to break a spring is to run up the RPMs before the oil gets circulated and up to temp. With a cam or high ratio rockers you really dont want to move until the OIL (not coolant) temp is around 120. Realisticly, I guess 100 is more reasonable. Hey, sometimes I gotta get to work! Defiantely nothing over 3k rpms until the oil temp is north of 170.
If that spring is rated for .600" lift, that is usually assuming it is properly oiled and at operating temperature. If you run a cold spring up to 4 or 5k rpms, you rolls the dice you takes your chances.
Not saying that's what happened, just a thought on a probable scenario.
Go down to 'Canes on Mission Beach get a pint of Pete's Wicked, watch the sunset and reflect on this wisdom...
Then go to Cheetah's and forget about that old broken spring!
Haven't been there is a number of years, and we definitely are lacking in the Mexican food arena here in the northeast. Although I think the outdoor heaters at Casa de Bandini would have a hard time keeping up with the snow
Do a search here and on LS1tech. I cant tell you how many people have had this happen to them. I recently had a customer that had one last 46 miles with the so called "new and improved replacements"
Rev Valve Springs are JUNK. Please see following thread. I had mine for less than a couple of monthes and they failed. I got new ones from Rev and they failed. Put the Crane dual springs on and have had no problems for about 5000 miles. My tuner sent the broken springs back to rev and politely asked why they had failed. He purchased many parts from Rev for his ported and polished heads and thought he had a pretty good relationship with them. They gave him a bunch of BS like, we don't know what the profile of the cam lobes are, how high he reved it etc. etc. He went over all my specs with them and they still had no answer. That is Crap and he is no longer purchasing rev parts after a 3 to 4 year relationship. A company that won't stand behind it's products and renames the same old crappy parts with a new # does not deserve our business and shouldn't be in business.
Sounds like they have some serious material issues. All of the really good clean spring steel comes from Japan. That's where most get their steel from for valve springs including Crane, PSI, etc.
