Difference between X and H pipe?
Old Dec 29, 2005 | 11:32 PM
DJ:BOTA's Avatar
DJ:BOTA
Default Difference between X and H pipe?
What do we have stock? Which one has more advantages?
Old Dec 30, 2005 | 01:29 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
We have an H as a stock pipe. The X alone will change the tone a bit. Not much else.
Old Dec 30, 2005 | 01:44 AM
Shane_S's Avatar
Shane_S
It's important to note that they accomplish about the same thing which is to balence backpressure. The X is a tad bit better.
Shane
Old Dec 30, 2005 | 02:06 AM
terlox's Avatar
terlox
I hear the X-pipe reduces 'popping' on deceleration in aftermarket exhausts.
Old Dec 30, 2005 | 02:25 AM
Shane_S's Avatar
Shane_S
It's supposed to. Dont think i noticed much of a change though.
Old Dec 30, 2005 | 03:58 AM
diviniti's Avatar
diviniti
St. Jude Donor '05
It really depends on what type of x pipe you get, as well as what type of exhaust system you have. i.e. headers/xpipe/straight pipes.
Old Dec 30, 2005 | 04:29 AM
Shane_S's Avatar
Shane_S
Probably didnt notice because i went from stock manifulds/H to headers/no cats/X all at once lol.
Shane
Old Dec 30, 2005 | 06:05 AM
diviniti's Avatar
diviniti
St. Jude Donor '05
Shane
I would guess you wouldn't notice it then..
Old Dec 30, 2005 | 06:42 AM
wrustywrench's Avatar
wrustywrench
X H ...... x flows a little better...... mine still pops with an x pipe....
bragging rights with a x pipe
Old Dec 30, 2005 | 07:45 AM
AU N EGL's Avatar
AU N EGL
It is like water running though a pipe. The less interferance with few corners in the pipe, smooth inner pipe walls and larger diameter pipe the better the flow and less back pressure which gives a few more ponies.
Sounds better too.
Old Dec 30, 2005 | 01:18 PM
DJ:BOTA's Avatar
DJ:BOTA
Thanks for the replies!
Old Dec 30, 2005 | 05:58 PM
Twisted99's Avatar
Twisted99
When I installed mine (Corsa) it changed the sound ALOT, still some popping, but it is definetly quieter than the stock H.
Old Dec 30, 2005 | 06:28 PM
BELVIN20's Avatar
BELVIN20
Have Corsa X Pipe, biggest differance I noticed was the tone changed and most of all the paper rattle sound the oringinal X pipe made was gone.
DJ:BOTA's Avatar
DJ:BOTA
Well, my plans are for the SLP Loudmouth to be installed. Should be quite the sound with or without the pipe!
Old Dec 30, 2005 | 07:19 PM
binkysgarage's Avatar
binkysgarage
I have both.
To Difference between X and H pipe?
