Part Number for these?
Old Dec 31, 2005 | 06:09 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Default Part Number for these?
Anyone know what would be the part number for the little black retainers/clips/fasteners that are used to hold down ABS lines to the rear cradle? I have a parts CD and I cant find them anywhere
I broke 3 of these at the time of clutch install and would like to get them now as I am replacing my differential soon
TIA
Old Dec 31, 2005 | 07:52 PM
FactoryRaceCar
TTT
Old Jan 1, 2006 | 02:00 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Err, you may be SOL.
I know that during my diff swap I noticed a few of the wiring harness clips might need to be replaced.. Found out from the dealer that they are not available as a seperate item, only included with a complete wiring harness!
Might be the same deal with these brake line clips, although you'd think they would sell them seperately.
You could also check with Gene at Karshop.
Old Jan 1, 2006 | 02:02 AM
FactoryRaceCar
Thanks for the reply. I will just use C clips from the hardware store
Old Jan 1, 2006 | 08:21 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Since I have had 4 rearends in my car, it comes apart alot. What we do now is simply zip-tie the lines in place.
Old Jan 1, 2006 | 05:05 PM
edensknight's Avatar
edensknight
Great tip!
Old Jan 2, 2006 | 11:07 AM
vettezeke's Avatar
vettezeke
Default Brake line clip repair
I broke the push in part off two of mine when I changed the differential out. I drilled a 1/4" hole in the clip where the tit had broken off and used a 1/4" bolt and selflocking nut to bolt them back. Be sure to stay away from the groove the brake line runs in when you drill the hole in the clip.
To Part Number for these?
