Is it possible...
Old Jan 2, 2006 | 02:11 PM
peter p's Avatar
peter p
Default Is it possible...
with the dual fuel tank setup, to siphon gas out of a C5?
Can one drain out a bad tank of fuel? How?
Can't find any answers to this question anywhere. However, I thought that I read somewhere that there was some sort of baffle or screen in the fuel fill neck that prevents passage of a siphon tube.
Old Jan 2, 2006 | 02:40 PM
indy300's Avatar
indy300
According to "All Corvettes Are Red" there is gas transfer (level equalization) between the two tanks. I don't see why you couldnt drain the tank. You may have to turn the car on to get the gas level transfer mechanism to work.
BUT I may be wrong on everything...
Old Jan 2, 2006 | 09:19 PM
Silver98's Avatar
Silver98
I believe the gas is transfered by a passive pump (eductor type) that functions by using the discharge of the motorized fuel pump. I can't quote the source right now, but I think I remember reading that you can not siphon gas out of the passenger-side fuel tank.
As far as solving your issue, I'm sorry I can't help. Maybe someone else will chime in, so here's qa TTT for you. Good Luck.
To Is it possible...
