Another Bose Stereo Question
Old Jan 3, 2006 | 07:49 AM
KN2000's Avatar
KN2000
4th Gear
Default Another Bose Stereo Question
This may have already been asked, but I can't seem to find it!!
Help!!!
I have the stock bose stereo system with the stock speakers...
(I know they suck but for now this will have to do.... )
I'm trying to install an aftermarket amplifier and a 10" sub I've tried using the rear speakers to get the signal but that didn't work. Can anyone tell me where to get stereo signal for the amp.
I have a 2000 Coupe....
Thanks!!!
Old Jan 3, 2006 | 09:50 AM
DPG's Avatar
DPG
St. Jude Donor '06
Here ya go
No wait sorry wrong link
Ok, here is a link in towards the right direction.
http://www.linkmeup.com/pd2.htm
You will need something like this. I know there are other brands as well and that you should be able to buy them at a best buy or other car stereo install place. Good luck
Old Jan 3, 2006 | 10:55 AM
simpleman68's Avatar
simpleman68
I always hate to be the bearer of bad news, but most aftermarket line drivers, adapters etc. make your system sound worse than it already does. Often there is noise interference, muddy bass and poor sound quality.
I know top quality sound may not be important to everyone, but you must be unhappy with some part of your sound to want to change it.
My advice:
Instead of spending $100 + on an adapter, consider upgrading speakers and head unit.
Get a better quality head unit like Alpine or Eclipse ($200-400 from Woofers etc.com) to feed that new amp.
If your spending money on an amp and a sub already, you really may want to consider this upgrade and get new speakers, even if it's just the doors to start out with.
I've heard so many folks put adapters into existing 2 ohm factory systems and they sound
I'd rather spend my money doing it right instead of doing it again.
Just my 2 pence.
Scott
Old Jan 3, 2006 | 10:59 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
DPG
Thanks!! Thats great info!! Whats the best adapter for installing an I POD interface?? That is my next Stereo mod!!
Bill C
Old Jan 4, 2006 | 10:01 AM
KN2000's Avatar
KN2000
4th Gear
....isn't there a way to tap into the existing wring from the back of the head unit and get RR and LR channel signals....
..if I were to change the head unit then I can't us any of the existing wiring I would have to rewire then entire stereo system....(at least that was what I have found out.)
Old Jan 4, 2006 | 10:17 AM
simpleman68
That's the trade off, having to rewire the whole system. If that's too much for you, then it makes sense to look into an aftermarket set up mentioned before. I'd go to the audio part of the Forum and check to see who's used a unit they are happy with. I've heard too many negative reports from guys there so I re-did my whole set up.
It's not too bad with help. I helped another Forum member re-wire his stereo, speakers and amp and it sounded and looked killer.
He bought an Alpine head unit with a face plate from Vrum Vrum here on the Forum.
Best wishes on the new set up whatever you choose.
Scott
Old Jan 6, 2006 | 02:47 AM
Grzldvt's Avatar
Grzldvt
There is a Tech Tip in the C5 section
https://www.corvetteforum.com/techti...=120&TopicID=1
This will explain how to tap into the low level outputs to add an amp and a sub. I have pulled all the Blose speakers, and replaced them with JL XR's, with a 8" JL Sub in the rear compartment powered by an Alpine amp.
I retained the stock HU to keep the look, not that it was all that good, but I have had too many systems taken from my cars.
I think it took me about 3-4 hours to rewire and mount everything.
Old Jan 6, 2006 | 01:17 PM
MattB's Avatar
MattB
I got the soundgate adapter and spliced it into the back of the stock HU. I took the advice in the audio section and just used it from the start. It works, but I'm having an issue with the remote power on , I don't think its the adapeter (as the remote power on does not go throught the adapter).
I have a 10 inch infinity, I think it really helps the low volume.
It was more work than I really wanted, but still pretty happy with the results. Taking apart the console and HU surrond is very easy. And when I ran the wires to the amp (I put it in the back) I took the opportunity to put in some frost king, which helped lessen the road noise. But it really added to the overall time.
I had replaced the twidlers in the doors with 3.5 infinitys (only $40 ) before I did the sub and they work pretty well togeter. The stock 8 inch subs in the doors kick in at mid volume and do help. Overall it help out a lot, but I'm sure it would be better to replace the HU and all the speakers. That may happen in the future, but I have other projects to that I want to do on the Vette for the near future.
By the way I have a 2000 coupe as well.
Old Jan 6, 2006 | 05:10 PM
TEN-99's Avatar
TEN-99
KN2000...You have a PM. If you have not read my posts on stereo upgrade, I suggest you do this before rewiring your entire car. Contrary to what some think (and everyone's opinions are valuable)The Delco HU is actually a very high quality unit and will perform very well. As I have posted, I have replaced the 3.5's and 6.5's, added a 12" Comp Sub and a 250w fosgate amp. I have won two contests for single amp systems and will put this setup against any comparable wattage system out there. WITH MY OEM HU! The PAC-VET1 adapter does a great job or giving 4 low level outs (2RT & 2LT). Feel free to PM or post with any questions.
Old Jan 6, 2006 | 06:10 PM
Kevin G's Avatar
Kevin G
I am considering replacing the twidlers myself. What Infinity model did you use?
Old Jan 6, 2006 | 06:23 PM
MattB's Avatar
MattB
Can't remember off the top of my head, 'reference' maybe? but I think they only have one 3.5 inch model. I got mine on clearance at circut city, I think they were making way for a new model. Its pretty easy, pop the door pannel and plug and play. I even didn't fully remove the door pannel, just pulled it out enough to get to the speaker.
Old Jan 6, 2006 | 10:15 PM
MgKenny's Avatar
MgKenny
Saw this link on EBay. Don't know if it's worth a crap. It IS expensive though.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
HTH
Ken
Old Jan 6, 2006 | 10:29 PM
capnmorgan's Avatar
capnmorgan
I have a '99 hardtop and have had a 10" sub and amp in my car for a couple years now. I used the rear speakers for my signal source for the amp. I dont know why everyone rags on the bose speakers, but I have had many other aftermarket sound systems and these bose sound as good or better than any of em. I have had my vette for five years, and love the sound.
No insult meant by this, but do you know how to install the amp and sub? maybe you need to play with flipping around your positive and negative connectioins. hope this helps. good luck.
To Another Bose Stereo Question
