Three angle valve cut - Where does seal actually occur
Old Jan 8, 2006 | 08:50 AM
vettenuts's Avatar
vettenuts
Default Three angle valve cut - Where does seal actually occur
Where does the seal actually occur on the three angle cut? The inner cut is very steep so it appears that the middle cut is the actual seal and the others are there to obtain desired flow characteristics.
Old Jan 8, 2006 | 08:56 AM
WKMCD's Avatar
WKMCD
The actual seal is not the angle cut itself. It is where the two outer most angles meet.
Old Jan 8, 2006 | 09:19 AM
vettenuts's Avatar
vettenuts
I lapped the valve and get the same pattern I would on a standard valve.
Old Jan 8, 2006 | 09:25 AM
WKMCD's Avatar
WKMCD
With valve grinding compound it will look like the entire middle angle cut is the seal. To really see the seal, take a magic maker and "paint" the seat and the valve angle and then "dry" lap them. You should see a thin line on the valve and the intersection of the angles on the valve seat. PM me for my phone number if you want.
Old Jan 8, 2006 | 01:45 PM
vettenuts's Avatar
vettenuts
Reason for the question is I have a couple of small scratches on the high angle seat, want to make sure there will not be a sealing problem.
Old Jan 9, 2006 | 07:48 AM
WKMCD's Avatar
WKMCD
If you can't get rid of them by hand lapping the valve take them to a GOOD machine shop and have them lightly dress them.
Good luck.
Old Jan 9, 2006 | 12:13 PM
vettenuts's Avatar
vettenuts
Lapped the valves, no contact where the scratches are. Nice even lap marks on the middle cut.
To Three angle valve cut - Where does seal actually occur
