Only half blinkers working, still hazard switch?
Old Mar 14, 2006 | 11:19 AM
xlr8shn's Avatar
xlr8shn
I have the stalk. Will replace it within the next couple of weeks (spring vacation is this week)
Old Mar 15, 2006 | 12:01 AM
B84RADR's Avatar
B84RADR
Originally Posted by SmoothFRC
Any update on this? I had my car at the dealer for this and of course it was not happening, so i am pleading with them to replace the stalk as that is what I think it is based on this thread (and also sounds like the hardest thing to change)
Any luck?
Well right after I got the turn signal ordered, my wife of 11 years and three children decided it was time for a divorce. She retained a lawyer a filed.
This week I am going to be dropping my car off to the repair shop to replace the turn signal. I decided I didn't want to screw around behind an airbag. He said he'd charge me $100 to do it. I figure that's a pretty good price.
I'll post again when I know for sure whether or not that this took care of it. But I'm pretty sure it will. When it started going bad, I could fiddle with the stalk and it would replicate the problem. As you probably know from my earlier posts, replacing the Hazard switch didn't do it for me.
Shayne
Old Mar 30, 2006 | 11:36 PM
xlr8shn's Avatar
xlr8shn
1. Remove the upper and lower steering column trim covers.
2. Remove the wire harness straps (2) from the steering column tilt head assembly (1) and the column.
3. Remove the wire harness assembly (1) from the wire harness strap (2).
4. Remove the two pan head tapping screws (1).
5. Remove the multifunction turn signal switch assembly (1).
Old Mar 31, 2006 | 02:11 AM
xlr8shn's Avatar
xlr8shn
Just completed the swap using benchpress' method listed earlier in the thread.
Hardest part was getting that darned tilt lever off.
Replacing the turn signal stalk fixed the problem...
Old Mar 31, 2006 | 08:35 AM
SmoothFRC's Avatar
SmoothFRC
I had the dealer replace mine under warranty with some persuasion, and it appears to have fixed the problem as well...
They "never" heard of this problem before....... Figures.
Old Apr 4, 2006 | 03:54 PM
B84RADR's Avatar
B84RADR
I just took my vette down to a local guy for replacing the turn stalk. I'll know for sure in a few hours if this solved the problem. I'm sorry I've been so slow at getting this done, I'm going through a divorce.
The first shop I took it to chickened out and said he didn't want to perform the repair.
The local guy here is going to charge $140 to replace it, well worth it in my opinion.
Shayne
Old Apr 5, 2006 | 04:11 PM
B84RADR's Avatar
B84RADR
I just wanted to report back and tell you guys YES!!! The turn signal stalk replacement, at $170 labor, fixed my turn signal problem. Wahoo! No more spastic, erratic right turn signal, it's all normal.
Shayne
Old Apr 5, 2006 | 04:19 PM
xlr8shn's Avatar
xlr8shn
Shayne
I'd have replaced it for you for a 12 pk of beer!
CONGRATS on the fix
Old Apr 5, 2006 | 04:27 PM
B84RADR's Avatar
B84RADR
CONGRATS on the fix
Ya know, I could have taken you up on that, but you would have had to come out to UTAH. lol
Shayne
