Brake Bleeding Problems
Old Jan 9, 2006 | 07:51 PM
vbrett2843's Avatar
vbrett2843
6th Gear
Default Brake Bleeding Problems
I installed new brake lines on my 2001 C5. I tried to bleed the brakes the "old fashion way" with no results. What is the proper way to bleed the brakes?
Old Jan 9, 2006 | 08:17 PM
Patches's Avatar
Patches
Pre-2001 uses the traditional pattern while 2001+ needs to be bled in the order: RR, LF, LR, RF.
Old Jan 9, 2006 | 08:25 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
While you're in there, install speedbleeders.
Old Jan 9, 2006 | 09:26 PM
vbrett2843's Avatar
vbrett2843
6th Gear
Can this be done with the conventional "pump the pedal" method?
Old Jan 9, 2006 | 10:03 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Yes, although it requires a very understanding girlfriend.
Old Jan 10, 2006 | 04:22 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
best low cost mod I have ever done...I bought mine from Vette Brakes.....I also went to Home Depot and bought a piece of vinyl tubing that I hooked to the end of the bleeder valve and ran it into a catch can.....
Old Jan 10, 2006 | 05:05 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
or open them all for a gravity bleed. Don't let the master go dry.
nice car
Old Jan 10, 2006 | 05:08 AM
VA 98 VETTE's Avatar
VA 98 VETTE
Start with the longest line first. Then next longest and so on.
Old Jan 10, 2006 | 06:31 AM
vbrett2843's Avatar
vbrett2843
6th Gear
Thanks for the help!
Old Jan 10, 2006 | 01:49 PM
dbirdz06's Avatar
dbirdz06
Speedbleeders
Old Jan 11, 2006 | 11:57 AM
indy300's Avatar
indy300
I don't understand what speedbleeders do or the advantage of them. Can someone please explain that. I will be replacing my brake fluid in the coming months and MAY want to put these things on while I'm in there. thanks.
Old Jan 11, 2006 | 12:21 PM
2KVetteMan's Avatar
2KVetteMan
Old Jan 11, 2006 | 12:48 PM
RJW's Avatar
RJW
From: Tinker till it blows... then back it off a notch, maybe!!
St. Jude Donor '08
They have a spring loaded ball in them. When the bleeder is open,and the brake pedal depressed, fluid pressure overcomes the spring, the ball moves and air/fluid comes out the end of the bleeder. WHen pedal is released, rather than sucking air back in, the ball blocks the opening .
Without it, you would have to dump up the brakes, crack open the bleeder and then close it before releasing the pedal.
Makes for a one man job.
Old Jan 11, 2006 | 07:01 PM
Armycop's Avatar
Armycop
And where does one purchase said speedbleeders? Sounds good!!
Old Jan 11, 2006 | 08:41 PM
RJW's Avatar
RJW
St. Jude Donor '08
speedbleeder.com, pepboys maybe and other places.
Old Jan 11, 2006 | 08:58 PM
Greg_E's Avatar
Greg_E
Speedbleeders and ATE Brake fluid.
The ATE brake fluid comes in the blue and the standard yellow color. If you currently have yellow fluid in the system, you buy the blue and bleed the brakes until the blue fluid comes out of the bleeder. The next time, you get the yellow and bleed the system until all the blue is purged etc.
Speedbleeder also sells a waste fluid collection bag. It looks like an I.V. bag. It's only about $6 , and I found it useful. Just crack open the bleeder screw, lay the bag on the floor and slip the tube over the bleeder. I didn't spill a drop, and didn't have to worry about the drain hose popping out of the container or knocking the container of waste fluid over.
Old Jan 11, 2006 | 10:49 PM
LoneStarFRC's Avatar
LoneStarFRC
What he said!
To Brake Bleeding Problems
Old Jan 11, 2006 | 11:31 PM
DngrZne's Avatar
DngrZne
I never knew there was a "traditional" pattern. What would that be? I'm going to be removing my calipers soon to repaint them and add stainless braided lines, so this would be good information to have.
Thanks,
Chris
Old Jan 12, 2006 | 12:29 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Oh,,,,by the way DONT LET YOUR MASTER CYLINDER GO DRY!! It's very easy to do with speed bleeders!!!!
BC
Old Jan 12, 2006 | 10:21 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Farthest from MC to closest: RR, LR, RF, LF
