346 Solid Roller install....
Old Jan 13, 2006 | 08:57 AM
9secondflat's Avatar
9secondflat
question
why a solid roller and not a hydrolic roller? isnt a solid roller for race only??
Old Jan 13, 2006 | 09:21 AM
Face's Avatar
Face
Originally Posted by 9secondflat
question
With a cam that radical, it probably has to be a solid roller.
Old Jan 13, 2006 | 09:25 AM
WKMCD's Avatar
WKMCD
Originally Posted by John Shiels
This is your motor? If so can't wait to see the results
That's Phil's personal motor.
I wish this was my motor. No, Phil just finished mine. Mine's an anemic little M6 C5 that runs around with only 460-470 RWHP. I just wanted something for running out to the grocery store, etc. Phil'S getting a set of 3.90's for me which should help it a little. Phil's tuning is second to none.
Old Jan 13, 2006 | 10:15 AM
Phil97SVT's Avatar
Phil97SVT
question
Who told you solid rollers were race only? Someone was wrong....
Old Jan 13, 2006 | 12:43 PM
supercoupe01's Avatar
supercoupe01
I like your set-up from the intake down. What couplers did you use? Did you custom build the ducting? Will it hook directly into a vararam? The colors look great with the valve covers and intake.
Good luck with it.
Old Jan 13, 2006 | 02:03 PM
Phil97SVT's Avatar
Phil97SVT
Good luck with it.
We used Hose Techniques 4" hose, used 4" aluminum U-bends and I tig welded it. Its going to bolt right to the Vararam and eliminate the need for the bottleneck MAF. Thanks! Eventually we're going to have a set of custom sheet metal valve covers made for both motors.
Phil
Old Jan 14, 2006 | 09:50 AM
Phil97SVT's Avatar
Phil97SVT
T T T - Motor should fire sunday afternoon assuming we can get the radiator support finished.
Phil
Old Jan 14, 2006 | 12:25 PM
big hoss 98C5's Avatar
big hoss 98C5
Old Jan 14, 2006 | 12:52 PM
SpinMonster's Avatar
SpinMonster
Low overhead, low pressure = high enjoyment
You forgot two other compnents to the equation that he has: Know-how and interpersonal skills
Old Jan 14, 2006 | 12:57 PM
SpinMonster
Phil, you're running the car in speed density without a MAF?
Old Jan 14, 2006 | 01:00 PM
Phil97SVT's Avatar
Phil97SVT
Guy,
Whats funny, we fired up Sam's car and after it warmed up we noticed that the LTFT weren't cycling. It was an old SD program. We're definitely going without the MAF and speed density 100%.
Phil
Old Jan 14, 2006 | 05:43 PM
wannabe-psi's Avatar
wannabe-psi
----snake bitten----
how much more does it cost to go solid roller!!
so the CR you are running does not require you to run race fuel?
Old Jan 14, 2006 | 06:31 PM
  #33
402Sam's Avatar
402Sam
Phil what do you got in the motor build. Did you buy everythig new?
Old Jan 14, 2006 | 07:30 PM
  #34
SpinMonster
Running higher octane is a requirement of dynamic compression and not that of static compression. The size of the cam on intake duration and lobe separation angle dictates where the intake valve closes while the picton is rising on the compression stroke. If the intake valve isn't yet closed while the piston is comming up then it doesn't start to build compression since the cylinder isn't sealed. The bigger the cam, the later the intake valve closes.
The compression then isnt a fuction of displacement then (static compression) but rather the displacement starting from the point the intake valve closes relative to the piston's position. Static compression such as his 12.3:1 is what it would be if the piston was building compression from the bottom of the cylinder and the intake valve was closed while in that position which is never the case.
Old Jan 14, 2006 | 07:40 PM
  #35
Phil97SVT's Avatar
Phil97SVT
No, just a tune thats dead on. Going to a solid roller probably costs 1700 or so.
Phil
Old Jan 14, 2006 | 07:42 PM
  #36
Phil97SVT's Avatar
Phil97SVT
Honestly, if I told you, you wouldn't believe me. I can get you a retail figure.
Phil
Old Jan 14, 2006 | 07:43 PM
  #37
Phil97SVT's Avatar
Phil97SVT
You hit the nail on the head. Its not SCR that determines if a car will run on pump fuel its DCR. Our DCR is in the mid to low 9s where our old motor was low 9s.
Phil
To 346 Solid Roller install....
Old Jan 14, 2006 | 07:59 PM
  #38
gsxzo6's Avatar
gsxzo6
whens it goin to the dyno...curious on numbers? also id like a vid thats things gonna scream.
Old Jan 14, 2006 | 08:19 PM
  #39
sams96's Avatar
sams96
With the way phil drives I see his car going deep low 10's maybe a high 9's with this new N/A setup. Who knows where it will go with the direct port nitrous shot.
Old Jan 14, 2006 | 08:22 PM
  #40
Phil97SVT's Avatar
Phil97SVT
I am not a big fan of the dyno, my car is tuned on the street for the street/strip.
Phil
