Another check engine problem
P1515 Command vs Actual Throttle Position Performance (PCM Module)
C1278 TCS Temporarily Inhibited By PCM
U1064 Loss of Communications with BCM
Half hour later at home, the car starts and runs fine but c/e light is still on.
Car is basically stock but I installed a new air bridge recently.
Anyone have any thoughts what it might be before I have to call the dealer?
And BTW, the "Service Engine" light will shut off after the third ignition cycle of the engine.
Before you get too involved with the PCM, there are a few simple things that you can check;
- There have been numerous instances where moisture or water leaking onto the Body Control Module (BCM) cause the dash to go CRAZY! The water can leak on the BCM from a couple of places. Check the BCM and the area around the BCM (Carpet and jute underlayment) and see if it is damp or wet.
Some 97 and eadly 98 models had defective Throttle Control Modules (TAC) and caused the car to go into the limp home mode! Been there!!!
You have an 03 so it probably not that.- The other thing that can cause some weird issues is a loose battery cable.
Recommend clearing the codes and see if it runs better or if the code comes back.
BC
BC
Thanks to all for your advise!
BTW, that U1064 is an occasional code that may pop up from time to time. Just like U1016 or U1096. These "U" prefix codes relate to communications between the various on-board computers and usually relate to the "SOH" (State of Health) test communications the PCM sends out over the serial data line each time the car is fired up. You will usually see them with the "H" suffix meaning it's a history code. Sometimes they may have a "C" (current) suffix or sometimes both an "H" and a "C" together.
As long as you don't experience an actual malfunction of some sort, they can be ignored. HTH
