draining radiator
Old Jan 16, 2006 | 03:19 PM
spirit73's Avatar
spirit73
Default draining radiator
Do you need a special tool to drain I found the plastic drain but it does not look like any petcock I have ever seen.
Thanks Larry
Old Jan 16, 2006 | 05:31 PM
Oldvetter's Avatar
Oldvetter
No special tool, but be careful, it onlys turns 90 or 180 degrees then can pull out. If you turn it to much it will break ($5 replacement at NAPA, don't ask).
Old Jan 16, 2006 | 05:33 PM
vettenuts's Avatar
vettenuts
Yup, 1/4 turn on mine and then it pops out slightly but the valve doesn't come completely out. It drains through the small hole under the support so make sure your bucket is in the right place
Old Jan 16, 2006 | 06:54 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
Use a 1/4" ratchet with an extension on it. Works perfect. I thought the previous owner had broken the plug until I discovered the 1/4" opening in the center of it. Good luck!
Old Jan 16, 2006 | 10:19 PM
spirit73's Avatar
spirit73
Default drain
Thanks to everybody that helped
Larry
To draining radiator
