Vararam Green Filter Picture
Old Jan 21, 2006 | 09:09 AM
out2run's Avatar
out2run
Default Vararam Green Filter Picture
Here is a picture of the 1.25 inch green filter that came with the VB2 kit.
Haven't even unwrapped it yet!
Old Jan 21, 2006 | 09:40 AM
Villain's Avatar
Villain
Cool. Let us know about the fitment once it's installed.
Old Jan 21, 2006 | 12:46 PM
vettenuts's Avatar
vettenuts
I am interested in fitment too. Did they make any changes to the housing to accomdate the new filter? Wondering if it will backfit as the Green actually filters better than the K&N I am using.
Old Jan 21, 2006 | 01:11 PM
Face's Avatar
Face
I don't know what happend to the one that they were supposed to send me....?
Old Jan 21, 2006 | 02:48 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Veteran: Coast Guard
Senior Member
Cruise-In V Veteran
Yes, please let us know how it fits. I too have a VR2B, and would rather have the green filter if it fits better than the foam filter.
Old Jan 21, 2006 | 03:35 PM
out2run's Avatar
out2run
Will be installed this Sunday.
Another friend who bought the VB1 will also install his same time.
I will get pictures of the differences, especially the sealing area around the greenfilter for you.
Old Jan 21, 2006 | 08:30 PM
GTB/ZR-1's Avatar
GTB/ZR-1
Are these supposed to outflow the foam filter that normally comes w/ the Vararam?
Old Jan 22, 2006 | 08:26 AM
vettenuts's Avatar
vettenuts
Outflow, I doubt it. Outfilter, definitely. The green filters were developed in Europe and are superior to the K&N filter in my opinion for two reasons, one the rubber seal doesn't intrude into the filter area thereby reducing the effective area and second they are a woven cotton base rather than gauze so the thickness is more consistant than the K&N.
Old Jan 22, 2006 | 01:48 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
I would also like to know if this filter is a direct fit or if it needs extra foam glued on to make it seal correctly.
Old Jan 22, 2006 | 04:13 PM
RWE 427's Avatar
RWE 427
Veteran: Marine Corps
Old Jan 22, 2006 | 05:13 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Senior Member
Cruise-In V Veteran
Thanks, we are all anxious to hear and see your results.
Old Jan 22, 2006 | 05:24 PM
Suprfun's Avatar
Suprfun
Old Jan 22, 2006 | 06:23 PM
out2run's Avatar
out2run
Ok........
Took three hours for us to install on my 03 coupe. Took less than two hours on my friends '02 vert.
The fit on the on '02 vette was excellent with the VB1 and the foam filter seamed to seal fine. We must be experienced, Ha!
I have pictures to post of the green filter fit on the 03' later tonight. We must have installled the scoops wrong because the top of the scoops are hitting the frame and are hard to bend upward to mate with the filter. I am also using the Halltech bridge from the stinger and not factory bridge.
I can't answer your question fully until I re-adjust the '03 system. I can tell that the thicker filter does seal, since the there is a foam on both surfaces between the filter. I assumed the '03 fit was due to the poor reviews some installers, but in our hast I think we may have not aligned the system properly. Will investigate.............
I also find the vararam much better quality than anticipated.
Old Jan 22, 2006 | 10:57 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Senior Member
Cruise-In V Veteran
Thanks for the info thus far, we look forward to the pics to see how the green fits compared to the foam.
Old Jan 23, 2006 | 05:40 AM
Silver98's Avatar
Silver98
You can adjust the angle of the rams from the bumper to the ari bridge by adding or removing either the top or bottom screws on the front duct where it bolts into the bumper openings.
That should solve your fitment issues.
HTH,
Joe
Old Jan 23, 2006 | 08:15 AM
out2run's Avatar
out2run
HTH,
Joe
I did screw the rams to the bumper tightly! Also, I noticed some rubber spacers and longer screws are included with the kit. It appears on the "poor instructions" that these spacers can be use to acheive the same results?
Old Jan 24, 2006 | 08:02 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Senior Member
Cruise-In V Veteran
Any pics of the installed green filter yet? Curious minds want to see how well it does or doesn't fit.
To Vararam Green Filter Picture
Old Jan 24, 2006 | 09:42 PM
out2run's Avatar
out2run
I will have to get back to your questions and newer pictures.
Re-adjusting the VB2 will be my Saturday project.
Went for a run on the interstates tonight. Car did feel stronger when going over 60mph, but the air tonight is great compared to past few days.
Old Jan 25, 2006 | 06:05 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Thanks for posting your experience's with the install,
did you use a shop type lift or jack & stands or ramps?
Old Jan 25, 2006 | 08:57 AM
out2run's Avatar
out2run
Did it all on front ramps. We had air tools which really helped with all the screws/nuts involved!
