I need gear info please!
Old Jan 21, 2006 | 09:11 PM
Gitusum's Avatar
Gitusum
Default I need gear info please!
i have a 97 and my auto trans went out on me.I figured while i have the trans out i would put 3.42 or 3.73 gears in the car.My question is this, what gears come in the 97 or was the 3.42 even a option or were they only on the newer C5's?I figure if i need to swap em now is the time but if i maybe already have em then no need to look for more gears.thanx for any help that can be given
Old Jan 21, 2006 | 09:30 PM
LoneStarFRC's Avatar
LoneStarFRC
The 3.42 was only available on the 6 spds. Now sounds like a good time for you to make the change. HTH
Old Jan 21, 2006 | 10:39 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
In 1997 all A4s came with 2.73 gears and all M6s came with 3.42.
So yours had 2.73s. 3.42s will give a noticeable improvement without sacrificing too much MPG. 3.73s are an option if you could care less about mileage.
Good Luck. Nothing like a failure to justify a desired upgrade
Old Jan 21, 2006 | 10:48 PM
Gitusum's Avatar
Gitusum
so what would be a good price for 3.42 rear or a 3.73 rear cost used?
Old Jan 21, 2006 | 10:51 PM
Lovin It!!! - C5
I've seen them listed (new full rear assembly) for around $1200. More if you want something raceworthy from someone like DTE.
Old Jan 21, 2006 | 10:56 PM
Gitusum's Avatar
Gitusum
all i need is the center and it doesnt have to be new and the only mods i have are the vararam b&b and a 160 stat so far maybe add a tune but thats about all the power i want.
Old Jan 21, 2006 | 11:00 PM
Mike Mercury's Avatar
Mike Mercury
source ?
what about the 2,739 that had the 3.15 ratio ???
Old Jan 21, 2006 | 11:23 PM
Gitusum's Avatar
Gitusum
how can i tell which gears i have?
Old Jan 21, 2006 | 11:37 PM
Mike Mercury
http://mikemercury.home.att.net/ratio.htm
Old Jan 22, 2006 | 08:44 AM
YO-EL's Avatar
YO-EL
If you have 3:15's now & want to go to 3:42's.. I have a brand new GM ring/pinion.. $250...
Old Jan 22, 2006 | 01:49 PM
Gitusum's Avatar
Gitusum
thanx for the help i looked and i have 3.15 in my car so will i or wont i need to make any modifications or changes to change gears to a 3.73?
Old Jan 22, 2006 | 02:23 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
With the mods you have the 3.73 will be a good upgrade. I say go for it
Old Jan 22, 2006 | 02:38 PM
Mike Mercury
with an A4, you will need a reprog.
Old Jan 22, 2006 | 02:41 PM
Gitusum's Avatar
Gitusum
yea but can it be driven til i can get it tuned? and is all that i will need to change? i can still use the original housing and stuff yes?
Old Jan 22, 2006 | 02:47 PM
Mike Mercury
you can drive with the shifter in "3" - and escape any error codes.
Old Jan 22, 2006 | 02:48 PM
Mike Mercury
http://mikemercury.home.att.net/342.htm
Old Jan 22, 2006 | 03:10 PM
Gitusum's Avatar
Gitusum
thanx mike fore the awesome info.now all i need to do is find me some 3.73 gears a A4 trans and im good to go other than a tune to reprogram the car and add some goodies! im just glad i dont have the 2.73 rear and have to buy a whole other rear money saved!
To I need gear info please!
Old Jan 22, 2006 | 04:09 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
For the trans check with Rodney at RPM he makes some killer A4's
Old Jan 22, 2006 | 04:12 PM
Gitusum's Avatar
Gitusum
i may have to do that and where can i pick up a set of 3.73 gears anybody have any on here?
Old Jan 22, 2006 | 04:40 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Hey pal..Sorry about your trans.......
Hey there....If you're interested, We build alot of these rears and build several automatic monsters each year....We can discuss any level of performance you are looking for......
The trans is complex and allows any level of performance your budget allows....
There are afew options with the rear diff as well...
One of the other things you should consider is a PRO TORQUE converter...It will permit your automatic to make awesome power with no compromises....You won't even know it's there unless you're on the throttle....
Lastly, tuning an automatic is tricky....for the car to have GREAT performance and good part throttle driveability and manners....you have to spend some time with it and the customer.....
Whatever you need.....WE CAN HELP!
Hope this helps,
Chuck CoW
