Wheel Offset question(s)
Old Jan 29, 2006 | 03:22 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Default Wheel Offset question(s)
To put it short, I am having a really hard time buying wheels for my C5.
Mainly because I don't know enough about offsets and don't want to do the wrong thing.
What is the Offset of C5 OEM 5 spoke wheels and OEM Z06 wheels?
17x8.5 = ?? Offset
18x9.5 = ?? Offset
17x9.5 = ?? Offset
18x10.5 = ?? Offset
I am thinking of putting 18x9.5 wheels on the front of my C5 and the offset that the repro manufacturer advertises is +65
This concerns me since I know so little about offsets.
Can someone help me with this?
Would I run into a problem with the 18x9.5 +65 wheel on the front?
Are my OEM 18.9.5's the same +65 offset?
If they are, I can at least try them up front to see how they fit, BUT I don't know the offset of my OEM wheels.
Can anyone explain the Offset numbers to me?
I have really found myself scratching my head trying to buy wheels for this car.
I'd really appreciate any help you guys can lend me here.
Glenn
Old Jan 29, 2006 | 03:46 PM
Erik88vette's Avatar
Erik88vette
I'm in the process of bying some wheels myself,but if you go for OEM or replica's the offset will be OK.
A link where you can find some offset and width...
http://www.factoryreproductions.com/
Search for corvette(obviously )and motorsport.
Greetz Erik.
Old Jan 29, 2006 | 03:50 PM
Glennm27's Avatar
Glennm27
Thanks Erik, BUT my big concern is the 18x9.5 wheel is designed for the REAR of the C5 and I want to put it up front.......
Old Jan 29, 2006 | 05:19 PM
Erik88vette
That would be no problem....
http://forums.corvetteforum.com/show...5&forum_id=103
Nice wheels and as you can see,a nice offset on the rear.
Greetz Erik.
Old Jan 30, 2006 | 07:39 AM
cenzo's Avatar
cenzo
Glenn, offset is the distance from the mounting surface to the centerline of the wheel.
C5 fronts, 17x8.5 are 56mm
C5 rears, 18x9.5 are 65mm.
ZO6 fronts, 17x9.5 are 56mm
ZO6 rears, 18x10.5 are 58mm
The rears will be further inboard about 9mm or 3/8 of an inch when mounted on the front. This shouldn't be a problem. There are some manufacturers out there that sell 18x9.5s with a 58mm offset
You can try your rears upfront, just ignore the warnings you may get.
Old Jan 30, 2006 | 08:59 AM
Glennm27's Avatar
Glennm27
Thanks Vince
Good info. I am going to try my rears on the front, even though they have bigger tires than I will use, I will get a good idea.
Appreciate your reply.
Glenn
Old Jan 30, 2006 | 10:02 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
The offset of a wheel is what locates the tire and wheel assembly in relation to the suspension. More specifically, it is the measured distance between the hub mounting surface and the center line of the rim. Below is an explanation of the various types of offsets which are pictured in the above graphic.
Positive Offset
A positive offset occurs when the hub mounting surface is on the street side (the side you see) of the center line of the rim. Most factory rims will have this type of offset.
Zero Offset
When the hub mounting surface is centered within the rim, it is known as a zero offset.
Negative Offset
If the hub mounting surface is on the brake side of the center line of the rim, it is considered a negative offset or “deep dish”.
I have run the rear 18 x 9.5 Magnesiums on the front w/o issue.......with a 275/40/18 on it!
Some more info......the offset is different to keep front/rear tires from extending past the top of the fender & 1/4 panel per European regs.
http://www.c5registry.com/Production/wheels.htm
OEM offset is at least +58 mm
Old Jan 30, 2006 | 12:09 PM
Glennm27's Avatar
Glennm27
Positive Offset
Zero Offset
Negative Offset
Awesome. Thanks for that!
Exactly what I needed...
Old Jan 30, 2006 | 05:28 PM
99 vett babycar's Avatar
99 vett babycar
I'm running 65 mm offset 18 x 9.5 on the front with 265 tires - 2 years without a problem. Hope that answers your original question.
Old Jan 30, 2006 | 05:45 PM
Glennm27's Avatar
Glennm27
That does, thank you!
I have gotten some great replies here to this post.
Thanks to all.
I am planning on 18x9.5 with +65 offset for the front with 265/35 tires so your info was very helpful.
Appreciate it.
To Wheel Offset question(s)
